0 Members and 1 Guest are viewing this topic. Read 14905 times.
Oh sorry, do you think it's better move this thread for another section? Please let me know, I have to say that when was creating this thread, i was in doubt, where exactly to create, here, speakers section, or amplifiers...Sorry if is not according to the "The Lab" theme...
Older Rotel multichannel amps can be a cheap way to get a bunch of channels, the RB-976 and RMB-1066 in particular. They can be getting a bit long in the tooth now but they seem quite reliable.IMO cheap is good when you're at the start of the learning curve.The other point that was mentioned (in a negative way, oddly) was speaker measurement - this is something you will need to learn or you will hit a wall. It's not expensive to do these days.
Again watch out for DIY proud papa syndrome. An assemble of amps and some sort of crossover is not an elegant solution or particularly inexpensive versus manufactured product you can listen to first. How many attempts, hours, and wasted parts will it take to "get it right"? How many years of experience did this "particular gentleman" have to invest to develop his speakers? If that's your thing, great.
Yes, it will need two of this, for amplify the 4 tweeters and 4 radial horns... in class a operation, as the amp have a class a operational selector, could be interest, appears not to be so expensive..
Yes, I said before, at first I think I will just build the passive crossover recommended on the speaker's plan, but I already researching about the options about go active, thanks for the advice.
