First post— diy upgrade polk tsx-220b???
0 Members and 1 Guest are viewing this topic. Read 1440 times.
Jmitchell3
« on: 24 Aug 2019, 02:52 pm »
Hello! Im brand new to diy audio, and ive been lurking on the gr research forum along with watching a ton of youtube videos on audio measuring and such.
Question is....what is a good way to jump into diy speakers? I have an old pair of polk tsx-220b bookshelves ive had on CL for months with no luck selling them. Is there anything i could do to upgrade them to make them more appealing to present day me? Lol. Ive read some say better internal wiring, capacitors, and damping material may help?
I took one apart and it was quite informative. See pics attached.
OR...would i be better off buying a cheap speaker kit and assembling that as a starting point? I have relatives that are into woodworking, and i have some computer engineering experience (i.e. electronics).
Thank you all and happy saturday!
Jeremy
Speedskater
  • Kevin
Re: First post— diy upgrade polk tsx-220b???
« Reply #1 on: 24 Aug 2019, 11:21 pm »
Have you checked at the Club Polk forum?
https://forum.polkaudio.com/
richidoo
« Reply #2 on: 24 Aug 2019, 11:25 pm »
Welcome to AudioCircle, and to DIY, Jmitchell3!
Modding the Polks would be informative and cheap, but in the end don't expect miracles by swapping caps and wiring. It will still sound mostly the same, with 10% improvement. But you will learn a lot and gain skills.
If you like doing DIY (and not just doing it to save money, which it doesn't) then you know you will eventually build new speakers, I strongly recommend for your first project using a popular, quality kit that is known to sound good and which has a following who can offer support and help if needed. Speaker design principles are fairly heady, and it takes time to become proficient. A failed project at the beginning could turn you off from a wonderful hobby. Better to invest in a good kit that you know (with some help) will turn out great, then you will learn so much from that that you can take on more difficult kit, or start to tinker with your first kit and learn even more, etc.
Selah Audio and GR Research are both sponsors of AudioCircle and they both offer well designed kits and excellent support. Check out their circles and websites.
Jeff Bagby has designed a good bunch of speakers for DIYers, and they all seem to be very well received. Kits are available on meniscus audio, partsexpress, and elsewhere. Discussion of his designs mostly on techtalk forum, and avsforum.
Troels Gravesen is a Danish DIY speaker designer affiliated with Jansen speaker parts mfg, which offers the kits for Troels' designs. The parts are excellent quality and the designs are very well done, and Troels offers good support by email.
Reading some speaker design books like Vance Dickason's "Loudspeaker Design Cookbook" and reading the DIY speaker forums like our Enclosures Circle, Tech Talk, DIYaudio etc will allow you to learn very fast, and choose what kits would be best for you.
