SOLD: Emotiva A100 Flex BasX Amplifier
0 Members and 1 Guest are viewing this topic. Read 1202 times.
aboroth00
« on: 12 Aug 2019, 04:04 am »
Up for sale is my Emotiva A100 amp used to drive my KEF LS50.  Fully functional and in good cosmetic condition. This is the 2nd generation with the front headphone jack.
SOLD
Local pick up in 92677 always welcome.
OVERVIEW
The BasX A-100 offers all the essential features that make a great audio component, like a heavy duty power supply, great sounding high-current short signal path Class A/B amplifiers, industry standard unbalanced audio inputs, and full-sized five-way binding post speaker terminals. The BasX A-100 delivers a solid 50 watts per channel into 8 Ohms and 80 Watts per channel into 4 Ohms; plenty to drive most speakers to satisfying listening levels. The BasX A-100 also offers several useful extra features that earn it the designation of Flex Amplifier. The BasX A-100 includes a standard trigger input and output, but it can also be configured to switch on automatically when it senses an incoming audio signal, which makes it perfect for use in a remote zone.
The BasX A-100 also includes a front panel Volume Control and a front panel headphone output. Fans of vintage equipment will especially love the sound of the headphone output on the A-100, which is derived directly from the main amplifier outputs through precision dropping resistors – like the great sounding headphone outputs on high-quality vintage gear. If you’ve found the sound of the headphone outputs on other modern equipment lacking, then you need to check out the A-100. Another special feature of the headphone outputs on the BasX A-100 is their ability to drive even the lowest efficiency planar headphones with ease. A pair of internal jumpers allows you to bypass the dropping resistors and route the amplifier outputs of the A-100 directly to the headphone output – and avoid the need for messy external adapter cables. The super quiet amplifier circuitry in the A-100 ensures a low noise floor, even with the direct connection.
« Last Edit: 16 Sep 2019, 04:52 pm by aboroth00 »
