0 Members and 1 Guest are viewing this topic. Read 4643 times.
So I have had the Stereo Maraschino for over a month now and am highly impressed! What a superb amp. I have the 48v version right now and have it paired up with some super efficient and easy to drive ZU Audio Omen Dirty Weekends. The combo is amazing. I did try it with my new Magnepan LRS’s but wasn’t quite enough juice. And as I understand the STM in 48v form puts out 125 watts per channel into 4ohms. I have always heard Maggie’s are demanding and now I am experiencing that for myself. So I am upping the power supply to 60v. Which the specs on that is 400 watts per channel at 4ohms. Which if that isn’t enough to easily drive the Maggie’s, I simply give up. Lol My question though is, can someone explain to me how the amp can go from 125 watts to nearly 4 times that at 400 watts? And that increased power to the STM, are there any concerns of it putting too much of a load on that amp? Especially driving power and current hungry Maggie’s?
Here's the LRS's impedance curve. More like 3Ω nominal than 4Ω!
Hey Tommy,Am I going to be okay with 48v DTM mono blocks into Maggie .7?
Well I can tell you one thing for sure, Tommy’s DAC is very, very special This DAC has given me a whole new appreciation for the amps.
The Cherry DPA will be a like a DAC with added features/processing. In fact, the balanced DAC portion of the circuitry is nearly identical to the DAC DAC 2 HS (slightly higher output swing). There is also a separate single ended output (stereo) with selectable functionality. Can't disclose the details just yet, but soon. There are multiple sources: COAX1, COAX2, Optical, and Analog.
I’ve had the amps for 3 years and I’m not the least bit interested in any other amp or amps out there. The Maraschino’s are truly end game amplifiers.I held off on the DAC for a long time because it only has one input. But now that I have it, I am completely astonished by how good it is. It has given me a whole new appreciation for the amps. Like the Maraschino’s the DAC DAC is truly an end game DAC.
Which DAC DAC do you have?
So by your banner sig, avatar, whatever you want to call it, you are using Spatials with the DAC Amp?
The 1 HS. I bought it off a doctor who said it kicked the shit out of far more expensive very highly regarded DAC by PS Audio. The only reason he sold the 1 HS is because he upgraded the the 2 HSV.
Spatial isn’t merely a brand, but an idea. And yes, I’ve been using Spatial speakers for the last 3 years now.
