**SOLD**AudioQuest Rocket 44 Banana Speaker Cables - 3 foot length (Pair) $125
0 Members and 1 Guest are viewing this topic. Read 374 times.
sean619
Condition is excellent. Please see photos.
I will cover the Paypal fees.
Will ship for a flat $7.90 anywhere in the US. Will ship to Canada. Can also do local sale in Seattle area
Offered at: $125. MSRP is $380
Audiogon user: seanheis1
From the Manufacturer:
Rocket 44 incorporates Perfect-Surface Copper+ into its blend of conductors. PSC+ has fewer grain boundaries, which reduces harshness in the sound. This carefully finessed combination of PSC and PSC+ enables Rocket 44 to deliver a clear and faithful presentation.
SOLID PERFECT-SURFACE COPPER+ (PSC+)/PERFECT-SURFACE COPPER (PSC) CONDUCTORS
This cable uses a carefully finessed combination of Perfect-Surface Copper (PSC) and extremely high purity Perfect-Surface Copper+ (PSC+) conductors. The astonishingly smooth and pure Perfect-Surface eliminates harshness and greatly increases clarity compared to OFHC, OCC, 8N and other coppers. Extremely high-purity PSC+ further minimizes distortion caused by grain boundaries, which exist within any metal conductor.
DOUBLE STAR-QUAD GEOMETRY
The relationship between conductors defines a cable's most basic electrical values (capacitance and inductance). However, even when those variables are kept in reasonably neutral balance, the particular geometric relationship between conductors greatly affects the sound. Star-Quad geometry is not only vastly superior to conductors run in parallel, but also to the same conductors as two twisted pairs.
CARBON-BASED NOISE- AND CROSSTALK-DISSIPATION SYSTEM
This cable's negative conductors are covered with partially conductive Carbon-Loaded Polyethylene. This remarkable material reduces radio-frequency garbage being fed back into the amplifier. The sonic benefit is exactly the same reduction in "hash" and improved dimensionality that comes whenever RF interference is reduced in an audio circuit. In addition, a carbon layer damps interaction between positive and negative conductors, and an external Carbon-Based Noise-Dissipation System reduces external interference.
FOAMED-POLYETHYLENE INSULATION (FOR ALL POSITIVE CONDUCTORS)
Any solid material adjacent to a conductor is actually part of an imperfect circuit. Wire insulation and circuit board materials all absorb energy. Some of this energy is stored and then released as distortion. Tower, however, uses air-filled Foamed-Polyethylene Insulation on both conductors. Because air absorbs next to no energy and Polyethylene is low-loss and has a benign distortion profile, Foamed-PE, with its high air content, causes much less of the out-of-focus effect common to other materials.
« Last Edit: 4 Sep 2019, 01:41 am by sean619 »
sean619
