Emotiva XPA-200 for sale - SOLD
0 Members and 1 Guest are viewing this topic. Read 683 times.
Phil A
« on: 5 Aug 2019, 02:18 am »
SOLD$350 Includes manual, power cord and shipping (and PayPal) to the Continental US
Emotiva XPA-200.  Light use in basically my third system, primarily used for the last few years as a UHD home theater (with an Oppo 203 and before that briefly with a 103D before I bought a UHD television and I own a whole 9 UHD movies).  Basically, at this point, it’s more or less broken in.  I upgraded the amp in main system and have moved the old main system amp into this system (and my second system has an integrated amp/DAC/streamer so I don’t need the Emotiva).
Emotiva XPA-200 Specifications:
Topology: Fully discrete, dual differential, high current, short signal path Class A/B
Number of Channels: 2
Power Output (rated power; THD < 1%): 150 watts / channel; into 8 Ohms; both channels driven.
        240 watts / channel; into 4 ohms both channels driven)
Rated Power Bandwidth (at rated power; 8 Ohm load): 20 Hz to 20 kHz + /- 0.045 dB
Minimum Recommended Load Impedance (each channel): 4 ohms (which equals one 4 ohm load or two paralleled 8 ohm loads per channel)
Frequency Response: 10 Hz to 80 kHz (+ 0 / - 1 dB)
THD + noise: < 0.02%
Signal to Noise Ratio (8 Ohm load): > 89 dB at 1 watt (A-weighted); > 110 dB at rated power (A-weighted)
Damping Factor (8 Ohm load): > 500
Speaker Output Connections: Full-sized 5-way binding posts; one pair per channel x 2
Power Supply: 90,000 uF of storage capacitance; 360 VA heavy duty toroidal transformer
Input sensitivity (for rated power; 8 Ohm load): 1100 mV
Gain: 29 dB
Input Connections: Unbalanced (RCA); one per channel
Input Impedance: 47 kOhms
Trigger Input: 5 - 20 V (AC or DC); <10 mA input current required
Trigger Output: 12 VDC; can drive any load up to 50 mA
Power Requirements: 115 VAC or 230 VAC +/- 10% @ 50 / 60 Hz (automatically detected and switched)
Front Panel Controls and Indicators: Standby; push button (changes color to indicate Standby or On); Status LEDs (one per channel); blue for normal operation; red to indicate a fault (may be disabled by rear panel Status LED switch)
Rear Panel Controls: AC Power switch; rocker switch (switches AC mains power); Status LEDs switch; small slide switch on left rear (disables front panel Status LEDs and dims Standby button halo lighting); Input selector; toggle switch (selects between balanced and unbalanced inputs)
Protection: The XPA-200 is protected against excessive operating temperature, shorted speaker connections, ground faults, and other common fault conditions.
Size: unboxed: 17" wide x 3.875" high x 19" deep
         boxed: 21 3/4" wide x 8 1/2" high x 22 1/4" deep
Weight: 31 lbs (37 lbs boxed)
« Last Edit: 9 Sep 2019, 11:30 pm by Phil A »
