Ava set 400 on ebay
0 Members and 1 Guest are viewing this topic. Read 2650 times.
Hydro
Re: Ava set 400 on ebay
« Reply #1 on: 4 Aug 2019, 01:35 am »
Snagged it, going to use it with some Alta Hestia's I recently purchased. I also have a R400 and will see which one works best.
jmc207
« Reply #2 on: 4 Aug 2019, 02:00 am »
Congratulations! Hope you'll post some comments comparing the SET 400 with your 400R.
Hydro
« Reply #3 on: 4 Aug 2019, 02:45 am »
Will do.
AvsFan
« Reply #4 on: 4 Aug 2019, 04:26 pm »
Nice catch!!!!! I just bought a pair of Maggie LRS’s and needed a great amp to pair them with and This is the amp I have my heart set on. $2100 right now isn’t doable. But $1500, I would have made it work! Enjoy and post impressions and a review!!!!
Hydro
« Reply #5 on: 4 Aug 2019, 06:37 pm »
I was really surprised to see one up for sale. I heard the SET amp at the Chicago audio show and it sounded great. I will post my findings when the amp and speakers arrive. As a great spare and an amp that won't have any trouble running the Maggies I would suggest something like Denon POA 2200 or 2400 off the bay. They are good into 2 ohms and put out tons of power.  I really couldn't find out what optical class A means, but the amp runs very cool at idle so it isn't true class A.
AvsFan
« Reply #6 on: 4 Aug 2019, 10:44 pm »
Yeah. That is surprising but sometimes you come across great deals on EBay. Yeah, the SET 400 is hopefully the last amp I buy for 15years. But thanks for the info on those Denon’s. They look legit and affordable for right now.
Hydro
« Reply #7 on: 4 Aug 2019, 11:12 pm »
I checked on the back of my Denon and it was made in Japan, which isn't bad. The specs show 200 watts into 8 ohm, 400 into 4 ohm and 600 into 2 ohm. I listened to mine this afternoon on a nice 2 channel system and it sounded great, dead quiet, great dynamics and imaging. These were the top of the line stereo amps in the late 90's and cost over $1000, a lot for an amp at that time. They have volume controls on the cd input but the normal input sounds better to me.
