What does a microphonic tube sound like
0 Members and 1 Guest are viewing this topic. Read 8978 times.
Yomaha
« on: 1 Aug 2019, 07:15 pm »
I have been noticing a sound that reminds me of the sound that train brakes make...that metal on metal high pitched sound.  It's not as loud as train brakes obv, but it is noticeable immediately after my gear turns on (45-second delay for tubes heating up).  It seems to go away after 15 or so seconds and I don't really notice it during playback.  I also have been feeling like the upper-mids/highs have been a touch on the harsh side lately.
Any feedback/opinions as to what I may be hearing greatly appreciated!
timind
  • permanent vacation
Re: What does a microphonic tube sound like
« Reply #1 on: 1 Aug 2019, 07:49 pm »
My experience with microphonic tubes is they ring with vibrations, kind of a whistling sound through  the speakers. Touching the amp in any manner could cause it.
If you tap on the tube(s) once the amp is warmed up and it produces no sound, the tube isn't microphonic.
Yomaha
« Reply #2 on: 2 Aug 2019, 01:10 am »
I could see whistling sound fit the description of what I'm hearing. Does a microphoic tube have any other sound characteristics besides the whistling?  Could that be what is causing the harshness in the higher end that I'm hearing?
« Reply #3 on: 2 Aug 2019, 01:24 am »
Hardly imo, using a tube damper made any change?
https://www.youtube.com/watch?v=13n1VCR6UXw
« Reply #4 on: 2 Aug 2019, 03:14 am »
This first 6sn7 tube is whistling:
https://www.youtube.com/watch?v=205__gxWJc8
rollo
  • Rollo Audio Consulting -
« Reply #5 on: 2 Aug 2019, 03:18 pm »
  Sounds like to me a tube gone bad. Just try another that simple. Good luck.
charles
audioengr
« Reply #6 on: 2 Aug 2019, 03:25 pm »
Tubes sometimes get some bad gas in them and powering on dissolves it.  They can also have a mechanical defect that changes as they heat-up.  You can sometimes tap the tube and it will go away. This is not microphonics.  Microphonics will make noise when you tap the tube.
Yomaha
« Reply #7 on: 2 Aug 2019, 06:13 pm »
I have rolled the tubes several times in my BHK250, and that tells me that it must be in my Modwright 9.0AE pre.  It's a pretty big pain in the rear to get to those tubes the way I have my rack set up.  I'll try tapping those to see if I get any microphonics, then roll.
viggen
« Reply #8 on: 2 Aug 2019, 07:10 pm »
sounds like money leaving your wallet  :popcorn:
avahifi
    • http://www.avahifi.com
« Reply #9 on: 2 Aug 2019, 08:22 pm »
Typically, you will get a PING sound through the speakers when you lightly tap on a microphonic tube.
Frank
Rusty Jefferson
« Reply #10 on: 2 Aug 2019, 08:39 pm »
Noise and microphonics are different things. Microphonics is what it's name implies. The structure of the tube acts like a microphone and amplifies sounds from outside the tube. If gently tapping the case of a piece of equipment, or the tube itself with your fingernail causes a lot of noise through the speakers, you can say that tube(s) is microphonic. In some severe cases, you'll be able to hear people walking across a floor through the system as the vibrational energy of the footfalls are amplified.
Hissing, spitting, pinging sounds are noise issues unrelated to microphonics. They are simply issues with the tube construction.  A tube can be noisy, but not microphonic, and vice versa.  Sometimes, a tube damper will control minor tube noise, and some tubes will quiet down after 10-20 run time.
When buying tubes, always request tubes that are low in noise and microphonics.  Especially important for preamps that have high gain.
Yomaha
« Reply #11 on: 3 Aug 2019, 05:52 am »
wut
twitch54
« Reply #12 on: 3 Aug 2019, 04:38 pm »
for the record the brakes on a train are not making that sound rather it's the flange of the wheel and the inside of the railhead on a tight radius curve.
twitch54
« Reply #13 on: 3 Aug 2019, 04:40 pm »
I've had that problem as well, 'Beano' usually works !
hagtech
    • http://www.hagtech.com
« Reply #14 on: 16 Aug 2019, 06:41 am »
Sounds more like a heater-to-cathode insulation breakdown.  Sort of a whistle / sizzle.  Cathode follower by any chance?
Yomaha
« Reply #15 on: 21 Aug 2019, 03:01 am »
I swapped the stock 5687's that came with my preamp and violá, all better. I guess I've had good luck bc that was the first time I've dealt with (or realized) I had a microphonic tube in all the years I've been fooling with tube gear (counting my guitar playing days🙂)
« Reply #16 on: 21 Aug 2019, 11:46 am »
Especially if the filament is AC heating.
Rusty Jefferson
« Reply #17 on: 21 Aug 2019, 11:49 am »
Again, noise and microphonics are different problems. Your tubes have noise issues, not microphonics.
Perhaps Andy can explain it if you contact him about the 5687s.
« Reply #18 on: 21 Aug 2019, 01:18 pm »
Dust in the pins can create noise.
Yomaha
« Reply #19 on: 21 Aug 2019, 05:33 pm »
Thanks for the info and clarification!  I'll be checking with Andy at VTS.
