SOLD: Pair of Duelund 0.01uF 600Vdc Silver Foil & Wax/Oil Bypass Capacitors
0 Members and 1 Guest are viewing this topic. Read 1008 times.
cal3713
**** SOLD ****
Original Price:  $264.00
Asking Price:  $125.00
I was using these capacitors in my Coincident Frankenstein 300b Monoblocks to bypass the 6EM7 coupling capacitors.  Doing so produced a significant increase in clarity and realism.
Only selling because I moved on from those amplifiers to First Watt F4s and was forced to remove a number of upgrades in order to make the asking price more palatable.
Here’s the review of them from HumbleHomemadeHifi’s capacitor comparisons (http://www.humblehomemadehifi.com/Cap.html):
“Sound: In one word: amazing! I have used these 0,01uF pure silver foil capacitors as bypass capacitors in many different systems. In just about every case there was an improvement in overall coherency and realism of tone. With realism of tone I mean that acoustic instruments and vocalists seemed much more tangible, more intimate. The Duelund Silver Bypass Capacitor brings out a certain harmonic richness in overtones, for example with brass wind instruments the tone gets a sort of "glow" making them so much more realistic. Big-band music is bright and warm at the same time if you know what I mean, just like in real-life. And now for a cliché: the Duelund Silver Bypass Capacitor really does remove a curtain from the sound, creating more depth, insight and it generally does a very good job in cleaning things up. It does this without getting harsh nor adding artificial emphasis on any part of the spectrum, something that can happen with certain types of bypass caps. They even scared me once: my personal reference system uses a 1-inch beryllium compression driver connected to a tractrix horn that flares out to 29 inches. This "tweeter" has no resistors in the signal-path and is driven by a first order network, so only one capacitor in the direct signal-path. It works like an acoustic magnifying glass. I was fiddeling around as usual, tuning the value of this capacitor in steps of 0,10uF but the sound didn't quite seem to fall into place how I wanted it to. Then I decided to listen if the 0,01uF Duelund   Silver Bypass Capacitor could help out here. Bingo! Makiko Hirabayashi's recording "Surely" (that I know very well) has some small bells that are used on several of the tracks. I thought I knew how they sounded but with the bypass capacitor in the network the bells were so realistic, it scared me :-) I am so pleased with these universal bypass capacitors that I have decided to keep them in stock. Verdict: add about 2 points to whatever capacitor you are bypassing”
See my feedback under cal3713 @ both Audiogon & USAudioMart.
« Last Edit: 22 Jul 2019, 09:24 pm by cal3713 »
DaveC113
  • ZenWaveAudio.com
Hi,
I'll take them off your hands... I'm in Lafayette. I'll send you a pm.
cal3713
sale pending
brj
Dang, I got beat by another local, no less?  :duh:
Enjoy, Dave, and if you decide you're tired of them.... :)
