Fuchs Tonearm Lowered Price
0 Members and 1 Guest are viewing this topic. Read 1104 times.
hifibuff
« on: 22 Jul 2019, 06:56 am »
This arm has never been mounted. I purchased it in 2008 direct from Robert Fusch himself as there were no US dealers at that time. All parts are made in a high quality. The metal parts from this one are made from aluminium or stainless steal. The armtube is made from Tigerwood. It is one peace including the headshell. The length of the tonearm is 315mm (about 12,5 inch). The distance between platter spindle and center of the armbearing should be about 302mm(11.89 inch). You can fix the tonearm with a 12mm stud and nut which can be screws
The tonearm wire is a high-quality copper cable, the length form output armtube to RCA is 110mm.
The armtube hangs on a strong magnet. A second, little magnet stabilize the armtube without contact from downside. So there is only a very small bearing friction. The arm seems to be suspended.
Included is an extra cartridge mounting plate.
New Asking $800 or b/o plus shipping from 94901.
« Last Edit: 9 Sep 2019, 02:09 am by hifibuff »
hifibuff
Re: Fuchs Tonearm Lowered Price
« Reply #1 on: 5 Sep 2019, 03:09 pm »
Bumped
hifibuff
« Reply #2 on: 9 Sep 2019, 02:10 am »
Bumped to $800 + shipping
