0 Members and 2 Guests are viewing this topic. Read 16328 times.
Preamps that use octals (6SN7, 6SL7, etc) have a more classic tube sound than those that use nonals (12ax7, 6922, 12at7, etc). Go for a pre using octals. For new production I'd rec the Don Sachs preamp that's generated a fair bit of buzz here on AC.
If you absolutely must have a remote control (at least for volume) One solution is the daisy chain a classic tube preamp to your current preamp. I am nearly always using two preamps together. And even three. no problem.I have four preamps in my system ... and three more laying around...As for octal tube sets. I agree they do sound more tube like than nine pin. particularly any modern 9 pin preamps.
I'm wanting to switch up my system. I've been buying and listening to tube stuff in my home that is generally getting good reviews in the sub $3k range. It seems that in most of the reviews I read about tube equipment, the gear is praised for sounding more like SS with a hint of tubes. I think I would like to try something that had a little more of the liquidity and lushness to it. My plan is to get a nice SS power amp to replace my Rogue chronus magnum integrated and get a tube pre with a classic tube sound to try out.I'm assuming in my naivete that I can't get just any well reviewed tube pre and change tubes to get what I think I want to hear? I think where I will run into trouble is that I need a remote.I guess in short. I'm not looking to squeeze the last little bit out of the recordings. Maybe some extra warmth and color would be nice?Thoughts?Who makes classic sounding tube pre-amps that I can get with a remote?
No remote but in the BEST catorgory Don Sachs SP14 right up there with the BIG NAMES costing $6000+ IMO
