0 Members and 1 Guest are viewing this topic. Read 5117 times.
Now that you have wired Ethernet at your DAC, you should not be using the router to DAC anyway. Add a good audiophile switch to the router and use this to drive your DAC. This will solve everything and sound a LOT better. I use the SOtM switch BTW, but there are cheaper options.Steve N.
Are there cheaper audiophile switch options or just cheaper switch options?
