SOLD: Micro Seiki DDX-1000 Turntable with MD-1000 Power Supply
0 Members and 1 Guest are viewing this topic. Read 2684 times.
Clio09
This is a Micro Seiki DDX-1000 turntable with original power supply and rubber mat. A heavy aftermarket copper mat and record weight are also included as is the Denon DA-302 12” tonearm with Denon headshell. Note that any tonearms other than the Denon DA-302 pictured are not included, and no tonearm cable is supplied. Mounting boards supplied include an AX-1G, AX-3, and 2 x AX-1. Up to 3 tonearms can be mounted simultaneously as seen in the photos. The table runs smooth and quiet and looks very good for its age, but to be conservative I will rate it 7/10.
This 1970s design was ahead of its time with separate power supply and two sculpted strobe markings around the 2kg / 31cm die cast aluminum platter. The starting torque is 1.2kg / cm and load characteristics allow the DDX-1000 to remain below 0,04% deviation up to a 3g load set at the outer limit of the platter. Speed accuracy is 0.03%. The height-adjustable feet contain a mix of inert damping (neoprene) and mechanical damping. The MD-1000 power-supply box holds the power on/off, start 33rpm, start 45rpm, and stop buttons plus two ± 6% speed controls.
Price is $1400. If your preferred method of payment is PayPal add 3.5% for the fee.
I purchased this table a few years ago locally and prefer a local sale/pick up (located in SF Bay Area), but will ship as well to lower US 48 at buyers expense.
« Last Edit: 17 Sep 2019, 02:31 pm by Clio09 »
nature boy
Re: FS: Micro Seiki DDX-1000 Turntable with MD-1000 Power Supply
« Reply #1 on: 14 Jul 2019, 07:22 pm »
A zip code or city location would be helpful😁.
NB
charlieboy
« Reply #2 on: 17 Jul 2019, 04:59 pm »
Message sent.
Thank you
Charlie
Clio09
« Reply #3 on: 18 Jul 2019, 01:21 pm »
Message received and responded to. Thanks for your interest.
Clio09
« Reply #4 on: 22 Jul 2019, 02:13 pm »
**Bump**
Clio09
« Reply #5 on: 29 Jul 2019, 02:14 pm »
**Bump**
Clio09
**Bump**
Clio09
Figured out a safe way to ship so now that option is available.
Clio09
« Reply #8 on: 14 Aug 2019, 01:39 pm »
**Bump**
orthobiz
« Reply #9 on: 14 Aug 2019, 07:35 pm »
It's such a cool item, hope it sells soon!
Paul
Clio09
« Reply #10 on: 20 Aug 2019, 01:54 pm »
**Bump**
Clio09
« Reply #11 on: 27 Aug 2019, 02:04 pm »
**Bump**
Clio09
« Reply #12 on: 4 Sep 2019, 01:44 pm »
**Bump**
Clio09
« Reply #13 on: 12 Sep 2019, 02:36 pm »
**Bump**
