Hornet Control
0 Members and 1 Guest are viewing this topic. Read 1599 times.
Don_S
Hornet Control
« on: 13 Jul 2019, 09:33 pm »
Anybody have good suggestions for large area hornet control?  I have a large front porch (stucco) where hornets like to hang out.  I only found two nests and splatted them with Hot Shot spray. But I need something to spray a larger area where the hornets just land but do not nest.
I would like the area to become toxic to them. But just keeping them away would be a benefit. An aerosol spray would be OK if it covers a large area instead of the focused foam products meant to squirt a relatively long distance.
aldcoll
Re: Hornet Control
« Reply #1 on: 13 Jul 2019, 10:21 pm »
There is a trap for wasp, hornet's and similar flying critters.  Just check with your favorite vendor be it Thezone,Home Dep or Wallyworld.
Just be aware these are attractant type or bait traps.
I don't know of a Toxic area spray outside of DDT or similar products and that would be more harmful and probably illegal.  It would probably kill any and all critters and that would create a bigger problem.
You might check with a local exterminator or county extension office.
Tread lightly and carry a big fly smacker thing.
Alan
Don_S
Re: Hornet Control
« Reply #2 on: 13 Jul 2019, 11:06 pm »
Alan,
Thank you for the suggestion.  A trap is more acceptable to me than spraying. I was not aware traps were available.  Off to Amazon Smile I go.  :)
aldcoll
Re: Hornet Control
« Reply #3 on: 14 Jul 2019, 12:09 am »
Be careful in trap placement as the ATTRACTION  factor.
Alan
