Unique cable search
0 Members and 1 Guest are viewing this topic. Read 973 times.
RikiSteven1968
Unique cable search
« on: 12 Jul 2019, 03:54 pm »
Greetings, colleagues.
I have a unique situation (I think). And I need HELP! 😊
So a few years ago, I commissioned a luthier (in Ireland) to build me my dream-guitar. It is a double-neck acoustic-electric, hand-made from Carbon Fiber. The guitar sports two 6-string necks, each tuned differently. The idea was to have an instrument that (ergonomically) allowed me to play either tuning, without stopping to ‘change guitars, or stop to re-tune a single guitar.
Originally, I ordered the guitar to not feature a microphone-supplemented pickup. This is because in the past, I always seemed to be cursed with on-stage feedback (when playing with others, amps, PA’s, drums, etc). So, I reasoned to go with Piezo pickups, only. I decided on installing two Dtar Wavelength 18v pickups (Seymour Duncan+Rick Turner design). So each neck has a piezo pickup (under the saddle) and thus, the guitar has two 1/4” TS connectors (on the side).
But her is the kicker. Later on, by accident, I acquired two small “overhead/choir mini condenser microphones” (phantom powered). These mics are the size of a pinky-finger. One day,, I dropped the mics inside my carbon Fiber guitar body. And after tinkering a bit with placement, levels, compression and EQ, I was caught by surprise by the tone and resolution I had stumbled upon.  The mics now capturing an extended image with more sustain. Perhaps they might not work best for live use. But at least in a studio environment, the mics gave me something desirable (and convenient).
So it got me thinking about the output section of the guitar; Needing two unbalanced outs (for the piezos) and two balanced outs (mini XLR), for the mics.  I don’t wish for a ‘spaghetti-mess of cables, feeding to amps or mixers (yuck)! I would like a manageable cord solution that preserves as much signal as possible. I am searching for a guitar snake, of which is not heavy and inflexible. Is Neutrik the better option for connectors?
 Love to hear your ideas😊, please comment!
Re: Unique cable search
« Reply #1 on: 12 Jul 2019, 04:06 pm »
Welcome Riki :thumb:
Neutrik are nice, I have see it less expensive than Furukawa.
Alnico pickups have great sound for guitar, you could made the cord yourself by stranded some copper OFC Teflon jacketed for better sound quality, but it may be more expensive than a assembled multi-ways cord.
Phil A
« Reply #2 on: 12 Jul 2019, 04:44 pm »
Welcome.  Places like - http://store.haveinc.com/  can also make various cables.
RPM123
« Reply #3 on: 12 Jul 2019, 08:17 pm »
Hi and welcome to the forum!
Perhaps you should check the company link below. They may be able to help.
http://audioenvy.com/store/
« Reply #4 on: 12 Jul 2019, 11:29 pm »
Greetings & Welcome to AC Riki   :thumb:
