Cutting Acoustical Foam... Electric Turkey Carver knife?
0 Members and 1 Guest are viewing this topic. Read 4935 times.
Oborous
What's the best way for clean cutting acoustical foam?
FoambyMail suggest an electric turkey carver, I currently don't own one, but if that's the Circle's concensus, I'll buy one.  I'm just thinking the oscilating blades will really make a mess of the edge.
I was thinking of taking my large (6") straight edge and fresh blades on a box cutter, multiple passes.
Help? :o
nathanm
« Reply #1 on: 2 Feb 2005, 04:02 pm »
Nope, no mess at all.  The carving knife is the only way you'll get a clean edge; it works like a charm.  Get a metal straight edge, put a piece of scrap wood underneath and you can cut perfect lines in the foam with a little practice.
Red Dragon Audio
    • http://www.reddragonaudio.com
« Reply #2 on: 2 Feb 2005, 05:00 pm »
I've watched custom car interiors put together where they cut that carpet pad -like foam with a knife very similar to an electric turkey carver.  I think they have a pro version meant for upholsterers but the turkey carver should be pretty darn close.
Sounds like a good idea to me.
John Casler
« Reply #3 on: 2 Feb 2005, 07:36 pm »
A close second to the electric carving knife is a softly serrated bread knife, but it takes a good hand and "no pressure" cutting strokes. 8)
« Reply #4 on: 2 Feb 2005, 08:22 pm »
Hmm, I guess this wouldn't qualify:
rosconey
« Reply #5 on: 2 Feb 2005, 08:30 pm »
thats a manual turkey cutter- for jive turkey's and such-
ctviggen
« Reply #6 on: 2 Feb 2005, 08:39 pm »
And, you can use it (an electric) to cut turkeys, too.  (I recommend brining a turkey, btw.)
nathanm
« Reply #7 on: 2 Feb 2005, 09:06 pm »
Quote from: Tyson
Well...how fast can you move your arm? :wink:
« Reply #8 on: 2 Feb 2005, 10:12 pm »
Well, I can move my right arm in a back and forth movement a lot faster than I can move my left arm.  Years of practice......
hmen
« Reply #9 on: 2 Feb 2005, 11:34 pm »
Quote from: Tyson
That's more information than we needed.
John Casler
« Reply #10 on: 3 Feb 2005, 12:15 am »
Quote from: Tyson
I trust that practice was not "with" the knife shown :nono:
