Adona Zero SR4 Audio Rack
0 Members and 1 Guest are viewing this topic. Read 799 times.
Don_S
« on: 26 Jun 2019, 03:28 pm »
Adona Zero SR4 audio rack.  Excellent condition.
Rack is 42.75" tall with the shortened top shelf supports but the columns can be cut if you want a shorter rack. Columns alone are 34". Top and bottom shelf supports have been changed but the rack comes with the new supports as well as the original.
Five shelves total. Three shelves 18"x18".  Two shelves 19"x24".  19"x24" shelf placed in a middle or bottom position is installed rotated 90 degrees to allow for deep components.
Includes all necessary shelf support brackets.  Shelf height and total number is adjustable.
$1650 Cash.  Local pickup only. Sacramento, CA 95829
Additional pictures available to serious buyers.
Note: Picture shows two racks.  The 4-shelf unit has been sold.
« Last Edit: 27 Jun 2019, 02:59 pm by Don_S »
JakeJ
Re: Adona Zero SR4 Audio Rack
« Reply #1 on: 26 Jun 2019, 06:58 pm »
Your ZIP code might be helpful.
tonyptony
« Reply #2 on: 27 Jun 2019, 12:56 pm »
PM sent
Don_S
« Reply #3 on: 27 Jun 2019, 03:02 pm »
Thanks for the reminder.  Location, location, location.   :duh:
I had copied the body of my Craigslist ad but my location was noted in a separate place. I modified my post.
Sunny Sacramento, CA 5829.
