0 Members and 1 Guest are viewing this topic. Read 13798 times.
Wow. What's with the high frequency rise?
Madisound recommed very small enclosure as the VAS = 1.2LI should use a bigger enclosure and lots of car hood brown stuffing to more bass.Suggested Enclosure 1.5 liters sealed and stuffed for F3 of 99 Hz 2 liters sealed and stuffed for F3 of 97 Hz 3 liters sealed and stuffed for F3 of 94 Hz
would you think it's possible to sim a folded TL for the SB10?The software have to offer the option of TL calc, not sure what are the ideal TL driver requirements, hobbists mostly used Morel drivers to TL floorstanders.
Hi FullRangeMan (do you use the same username on that other forum?)I played around with WinISD and found the following, all sealed and stuffed:10 liters, Qtc 0.99, F3 75.8Hz (Golden Ratio: 348*215*133mm enclosure)5 liters, Qtc 1.034, F3 77.5Hz (Golden Ratio: 276*171*106mm enclosure)3 liters, Qtc 1.089, F3 80.9Hz (Golden Ratio: 233*144*89mm enclosure)I kinda think a wide and shallow golden ratio will look good, with mirror-image driver placement slightly off center. Also hoping it will help with diffraction.At the same time, the dimension for the 5 liter sim above is similar to various folded TL designs for FF85WK, for example. I know the two drivers have different specs, but would you think it's possible to sim a folded TL for the SB10?What do you think?
