0 Members and 1 Guest are viewing this topic. Read 18931 times.
I don't think it's a good idea. Read the following link to better understand why there are issues with this approach:[size=78%]http://lightharmonic.com/blog/2015/07/24/power-supplies-and-noise/[/size]
Actually some of that is a bit misleading. The performance of batteries varies a lot with type, brand, and size. And I (and a group of inner circle friends) have tried a ton of them. So we've learned how to get the most out of them and in most cases the pros really outweigh the cons and the overall performance is not only very high but at a much lower cost than standard power supplies. The batteries are also consistent regardless of where you take them. A/C noise varies all over the place depending on where you go.
Tommy,If maraschino can run from a 12V source voltage right now, Dave at P.I. Audio already makes this:https://www.audiocircle.com/index.php?topic=111257.0which sounds kind of like what you were talking about in a "battery power supply" for maraschino?Come to think of it, considering there are 36V and 48V supplies right now for maraschino, couldn't one just string a series of three or four 12V batteries together to get the called for source voltage, or am I mistaken thinking maraschino's replaceable power supplies are right now DC supplies and they are actually feeding AC in to maraschino with the DC conversion happening inside the amp? Based on what I thought I remembered reading in the other thread, you were discussing a need for a DC-DC conversion, so I don't think this is the case?It reads to me like you're already there, maybe just not as elegant as going from wall -> ctek charger -> one 12V battery -> maraschino?
With some modifications, Maraschino monoblock boards can run from 12VDC. However, voltage drop from a BATTERY, with no regulation, over time will affect performance, and the power output will be quite low (gets lower as the batter discharges).
A DC/DC assures no droop and allows a boost function, converting low voltage, high current to high voltage, low current. The rail caps hold rail voltage through peaks of higher current draw and even out the “load”. Handling the dynamics of music is another part of this puzzle.
Leave it be IMO. Danny was showing a complete system. Maybe it was just synergy. I own two Dodd battery powered devices BTW. My experience is lack of dynamics and weight as opposed to AC powered.
Only way to really know is to build one and compare to original and stop guessing.
I love the sound I am getting from the little chip amps. I just wish I had that sound but more power.
But I would request an amp with single ended inputs this time.
None of Tommy's amps have single ended inputs, but he does supply an adapter.
We can also customize and put RCAs where the XLRs usually go! This kills the ability to upgrade to balanced in the future, but it skips over the adapter (shorter signal path). That also saves space in some cases.
Great. I have a selection of really nice RCA cables, but it is hard to find really good XLR cables.
These test as well as the ones Audio Precision includes with their $30,000 analyzers:Audio 2000s E02101P2 XLR Male to Female 1 Feet Microphone Cable (2 Pack) https://www.amazon.com/dp/B00O5UBK5U/ref=cm_sw_r_cp_api_i_0y7eDbEDBBKCE$11/pr !!
