BR2 code ?
0 Members and 1 Guest are viewing this topic. Read 2272 times.
redbook
  • the music is the blood...........
BR2 code ?
« on: 20 Jun 2019, 10:08 pm »
 Hello folks . Could someone tell me what the BR2 code is for the BP 26/25. I had it working fine but lost the preamp setting when I changed the batteries this week  Thank you.  :scratch: :thumb:
CanadianMaestro
Re: BR2 code ?
« Reply #1 on: 20 Jun 2019, 10:33 pm »
try 721
won ton on
Re: BR2 code ?
« Reply #2 on: 20 Jun 2019, 11:47 pm »
redbook         Did you lose the code for you're bcd 3 too.
redbook
Re: BR2 code ?
« Reply #3 on: 21 Jun 2019, 11:34 pm »
redbook
Re: BR2 code ?
« Reply #4 on: 21 Jun 2019, 11:35 pm »
redbook         Did you lose the code for you're bcd 3 too...No just the preamp. :scratch:
redbook
Re: BR2 code ?
« Reply #5 on: 22 Jun 2019, 01:45 am »
Well 721 doesn't seem to work....perhaps I have forgotten  the  way to enter a code.... :duh:
CanadianMaestro
Re: BR2 code ?
« Reply #6 on: 22 Jun 2019, 01:50 am »
http://www.bryston.com/PDF/Manuals/300020[BR2].pdf
1ZIP
Re: BR2 code ?
« Reply #7 on: 22 Jun 2019, 04:33 am »
Calypte
Re: BR2 code ?
« Reply #8 on: 22 Jun 2019, 09:46 pm »
srb
Re: BR2 code ?
« Reply #9 on: 22 Jun 2019, 10:33 pm »
Page not found.
That's because for some strange reason, Bryston uses square brackets in some of their document names.  That won't work as a hyperlink in any software that interprets a pair of square brackets as HTML tags.
You can copy the complete PDF filename and paste it into your browser's address bar, however.
redbook
Re: BR2 code ?
« Reply #10 on: 22 Jun 2019, 11:36 pm »
 Well it worked once I found the PDF  on the BR2...it's all there   thanks for everyone's input. Go to the BR2 on Bryston  page and click on the PDF ... :thumb: :thumb:
