SOLD: Goldpoint SA2-47 Passive Preamp
0 Members and 1 Guest are viewing this topic. Read 1627 times.
Cave
« on: 16 Jun 2019, 09:03 pm »
Goldpoint SA2-47 Passive Preamp, excellent condition, no issues. This is the 47 step attenuator,
From the website: http://www.goldpt.com/sa2.html
No distortion is added to your signal path while performing level control.  (Active preamps add in at least some distortion.)
Selector switch: 2-position - for two signal sources.
Goldpoint precision stepped attenuator for low noise and excellent channel-to-channel signal level matching.
LINE IN 2 / AUX can be changed easily to be:
     1) Second Line Input (factory default).
     2) Tape Output.
     3) Main Output #2.
Volume Control: Goldpoint low-noise, precision Stereo 24 or 47 Position Stepped Attenuator.
Selector Switch: Goldpoint 2P-2T-1D
Inputs & Outputs: Two Stereo sets of Inputs and one set of Outputs.
Rear Panel RCA Jacks: Gold-plated, heavy duty solid brass, right angle PC board style.
Wiring: High grade, silver-plated copper, multi-stranded, with Teflon jacketing.
Chassis: Aluminium clam-shell, 1/4" front and rear panels.
Dimensions: 2.3" Tall  x  4.7" Wide  x  7.0" Long
Weight: 1 1/2 lb..
Asking $350. Buyer pays shipping and any PayPal fees. You can get a ballpark from 97006.
I'll accept a money order as well to save the PP fees.
Ships from 97006 Oregon, pickup is welcome in the metro-Portland area.
« Last Edit: 2 Dec 2019, 03:52 am by Cave »
Cave
Re: Goldpoint SA2-47 Passive Preamp
« Reply #1 on: 31 Aug 2019, 03:34 pm »
bump 340
Cave
« Reply #2 on: 16 Nov 2019, 04:35 pm »
bump 325
