4BSST2 Problem
0 Members and 1 Guest are viewing this topic. Read 1265 times.
Dilbert
4BSST2 Problem
« on: 14 Jun 2019, 07:09 pm »
Folks, my 4B that powers subs went nuts. After an hour or two, it started pumping massive low frequency pulses causing the entire house to shake like it was Armageddon!
Anyone have similar issues with theirs?
Elizabeth
Re: 4BSST2 Problem
« Reply #1 on: 14 Jun 2019, 07:32 pm »
Not enough info... Did it still do it after disconnecting inputs?
If all you did was shut it off. Then you do not know it was the amp, or something else causing it.
Dilbert
Re: 4BSST2 Problem
« Reply #2 on: 14 Jun 2019, 07:37 pm »
Nothing upstream (preamp, crossover, EQ) was turned off - only the amp. It hasn’t done it again, by the way, after being used many times since. Very strange, indeed!
Elizabeth
Re: 4BSST2 Problem
« Reply #3 on: 14 Jun 2019, 08:48 pm »
Then you really do not know what was actually happening. You do not know if it was some upstream device, or the amp.
Personally if it has not happened again, I would call it a 'visit by naughty teenage  extraterrestrials' and ignore it.
Dilbert
Re: 4BSST2 Problem
« Reply #4 on: 14 Jun 2019, 09:07 pm »
LOL! Actually, the level LED’s on the upstream gear weren’t showing anything abnormal. Only the amp was vacillating between clipping on both channels as it pulsed.
Amazingly, it didn’t fry my woofers. Kudos to JBL!
