Balanced Tube Preamp Recommendations for $2000
0 Members and 1 Guest are viewing this topic. Read 1284 times.
stgrim
« on: 13 Jun 2019, 02:56 pm »
Hi All,
I'm looking for a balanced tube preamp, must have remote, xlr in and outputs and HT bypass, preferably used and would like to seek your advice.
Budget is $2000.
Have shortlisted the Aesthetix Calypso and Audio Research LS17 SE. Any other candidates I should think about?
Will be using it to drive a pass labs XA30.5. Primarily using it because I want to consolidate and use one set of speakers for both my HT and 2 channel listening. Was previously using my m2tech young dsd DAC to directly drive my amp.
Thank you for your advice in advance.
