Hello from Kingston, Ontario
0 Members and 1 Guest are viewing this topic. Read 1755 times.
skyforger
« on: 9 Jun 2019, 12:12 pm »
Good morning from Kingston, Ontario, Canada.
I started with a simple Yamaha amp and a pair of Energy speakers (about 25 years ago), and while on tour in Afghanistan (and with maybe a little tax free cash burning in my pocket) decided to improve my audio experience on the move to using an Astell&Kern player or an audioengine D1 on my MacBook Pro using Fidelia as software to play FLACs of the best recordings I could get along with a pair of PSB M4U headphones.  Just that improved resulted in me trashing a lot of the recordings I had as the increased level of transparency from the setup led me to detect a lot of really poor studio engineering.  I spent the next while on the hunt for good recordings which I got from sites like QOBUZ.  When I moved back to Canada I decided to invest in a new setup and decided to go with some Cambridge Audio equipment.  I currently have a CXA80 amp which I use with their CXN player which makes it very easy to connect to a hard drive full of FLACs.  So far so good.  I then got a set of used Paradigm Monitor 9v6 speakers and some Unity Audio Solid Link speaker cable as I reasoned that I would get better value for money buying Canadian speakers in Canada (still not sure about that one, but I digress).  I made what I think is an upgrade to the desktop setup - Fidelia has a crummy interface so I switched to Audirvana Plus and a pair of Bowers&Wilkins P7.  The result is coldly transparent which is great for a lot of the music I listen to.  Two things I would like to do with my setups - get a better set of floor standing speakers, and get something warmer sounding in terms of an amplifier for my desktop setup.  I have looked at a lot of items online but unfortunately I live in a small city which doesn't have much of an audio shop community as there is only one store and they don't keep much in stock, which is a crummy business model as I suspect most folks want to hear things before they buy them, myself included.  I prefer buying used as most items quickly lose value, our local kijiji is full of speakers bought for $3k and selling for $800 - unfortunately they aren't brands I have much interest in.  I will also be moving to Washington, DC, this summer, and my new place is a four storey town home.  One of the challenges I will have is that I want to listen to music in the kitchen (2nd floor), living room (2nd floor), and my formal music listening area (4th floor).  So at this point I had a bunch of questions and was hoping to take advantage of this online community to ask which is why I joined up.
1) With a budget of $500 US, what would be a significant upgrade to the audio engine D1 to warm things up?
2) With a budget of $2000 US, what would be the best bang for buck upgrade to the Paradigm speakers?  My local audio shop sells Castle, Focal, and Monitor speakers which I don't know much about, but I am not against waiting to get to DC to find something on the local used market.
3) Using the Cambridge Audio CXN as a base, what would be the best way of getting music to the three rooms?  I am not against getting additional amplifiers.
Although I think a good set of speakers should be able to play any kind of music well, it's always cool to know what others are listening to.
I am a huge fan of Tangerine Dream and Ulrich Schnauss, and I also listen to a lot of piano-based jazz (Brad Mehldau, Keith Jarrett, Bill Evans, Chick Corea) and some classic heavy rock/metal (UFO, Iron Maiden, Deep Purple, Ghost) with a dash of J-Pop (Utada Hikaru, Perfume) and soundtracks from composers like Yoko Kanno and Kenji Kawai.  Basically the audio setup will get a full spectrum workout.
Thanks for your patience in reading this,
Sean
Re: Hello from Kingston, Ontario
« Reply #1 on: 9 Jun 2019, 03:43 pm »
Greetings & Welcome to AC Sean   :thumb:  Fear not, you'll get lots of input from a lot of generous & knowledgeable folks around here. Enjoy the hunt. Have wanted to pick up some Yoko for some time, just not willing to pay the price so far. If I really feel a need I just run some Cowboy Bebop.  8)
Phil A
« Reply #2 on: 9 Jun 2019, 05:51 pm »
Welcome to AC!
Phil A
« Reply #3 on: 9 Jun 2019, 05:52 pm »
There are also brands that sell direct to the consumer with an in-home trial period.
skyforger
« Reply #4 on: 9 Jun 2019, 06:45 pm »
Thanks!  Yoko has made some really amazing music and is such a talented composer, I highly recommend her work on Sakamichi no Apollon (Kids on a Slope) and Turn a Gundam.
S.
ntjetsmoke
« Reply #5 on: 9 Jun 2019, 08:58 pm »
Welcome to the AC, Sean!
Wind Chaser
« Reply #6 on: 9 Jun 2019, 11:20 pm »
Welcome!
« Reply #7 on: 10 Jun 2019, 09:12 am »
Welcome.
I'd wait until you get to D.C. so you can audition lots of options.
Check out audiosciencereview.com for lower priced DAC/preamps, I believe the DX7s is still a strong contender in that price range.
Recommend reading Floyd Toole's "Sound Reproduction" 3rd edition to learn the basics of how speakers/rooms interact.  Toole would suggest monitors plus multiple subs.
jdoyle
« Reply #8 on: 10 Jun 2019, 01:42 pm »
Sean
What? Being from Kingston, You gotta list “The Hip”... :lol:
Welcome and have fun with your search, the journey is one of the best parts of this hobby.
JD
skyforger
« Reply #9 on: 10 Jun 2019, 02:01 pm »
JD
Hi JD, thanks for the welcome.  I'm actually from Quebec City, but I may have seen the Hip a few times.  I'm already neck-deep in a search for speakers - I like the ones I have but there certainly is room for improvement.
Sean
skyforger
« Reply #10 on: 10 Jun 2019, 02:04 pm »
Welcome.
Thanks for the recommendation, I will have a look.  Monitors and subs would definitely be an approach I need to learn more about.  Checking out the audiosciencereview site now, it's new for me so I've got reading to do!
Sean
FireGuy
« Reply #11 on: 10 Jun 2019, 06:10 pm »
Next time you're in Dwight, look up Axiom Audio.  Great vendor and great products.  Compete very nicely with PSB... also Canadian.  Only 321 KM x 2.
