SP3 Documentation
0 Members and 1 Guest are viewing this topic. Read 1139 times.
dminches
SP3 Documentation
« on: 6 Jun 2019, 02:36 am »
Is there a resource which explains what each of the configuration options for the SP3 does?  The manual just scratches the surface.  I would really like to know what things do.  Why allow the user to change the setting if you don’t tell him what it does?
  • The Demo is Everything!
    • http://www.bryston.com
Re: SP3 Documentation
« Reply #1 on: 6 Jun 2019, 09:53 am »
Hi
I do not believe we have any documentation other than the manual.
james
dminches
« Reply #2 on: 6 Jun 2019, 11:31 am »
Hi
james
What is the best way to gain an understanding of what each of the settings does?  Is there someone I can send a list to for an explanation?
I don't want to just change something haphazardly.
« Reply #3 on: 6 Jun 2019, 12:19 pm »
Stan at Bryston would be the best option.
james
Stan Bleszynski <[email protected]>
Buseto
« Reply #4 on: 6 Jun 2019, 03:56 pm »
Hi Dminches,
I'm not sure if this helps you : http://support.bryston.com/firmware/sp3/
On this site you find all the docs about the soft- and hardware updates. I found them always informative.
dminches
« Reply #5 on: 6 Jun 2019, 04:27 pm »
Hi Dminches,
Thanks.  I refer to that at times.
