A370peq toggle broken
0 Members and 1 Guest are viewing this topic. Read 933 times.
rockdrummer
« on: 1 Jun 2019, 10:49 pm »
Hi guys, I already emailed Rythmik, so I'm just asking in case someone has dealt with this or has any life-saving advice.  The switch arm for the rumble filter is wiggly and wabbles around on one of my servo amps. The underside of the switch is under the large board so I can't see it. I don't know if I can even do anything by loosening the top of the  switch to monkey with it.
Don't know for sure, but I think I have had them close to 3 years.
Ben
mikeeastman
Re: A370peq toggle broken
« Reply #1 on: 2 Jun 2019, 03:57 am »
There should be a nut on the switch shaft, it just needs to be tightened up and that should fix it.
rockdrummer
« Reply #2 on: 2 Jun 2019, 04:29 am »
Mike, thanks for the response, but that's very tight.
Ben
mikeeastman
« Reply #3 on: 2 Jun 2019, 01:00 pm »
Then it sounds like the switch is broken and will have to be replaced.
