Harman Kardon X-I X-II
0 Members and 1 Guest are viewing this topic. Read 1146 times.
bboyblaster
« on: 31 May 2019, 07:46 pm »
A unique chance to become the owner of a smart pair of amplifiers from the legendary line Citation of the American company Harman Kardon: the power amplifier X-I and the pre-amplifier X-II. The power amplifier has an operating mode switch; in the class “AB” (Normal) and in the class “A” (High) it is able to shortly deliver a current of 100! A. On board the second, in addition to the standard set of adjustments, there is a MM / MC phono-amp of the reference level and the same reference level - an amplifier for headphones. Both devices are built according to the scheme "double mono" have unique technical solutions and are one of the most prominent representatives of the classical school of sound. American amplifiers with a corresponding large-scale sound, while collected at the Japanese plant of the company and for the Japanese domestic market with the highest build quality and configuration, a unique symbiosis. The sound corresponds to all the canons of the Hi-End (the price of the kit in retail at the time of release (1982) is about $ 12,000). It has no genre preferences, you can listen to any music with the maximum involvement in the process. Amplifiers can handle even very tight acoustics, but to unlock their full potential - acoustics must be of comparable level.
X-I characteristics The rated output power is 2x150 W (8 ohms) with 0.05 THD at 4 ohms 240 W. Frequency range 10 Hz. -100 kHz. Harmonic distortion below 0.01% The rate of increase of the signal 200 V. / m.second Dumping Factor 130 Signal to noise ratio 118 dB. Dimensions: 440x195x428 mm. Weight: 25 kg.
Characteristics X-II The frequency range is 0.1 Hz.-300 KHz. Harmonic distortion 0.006% The rate of increase of the signal 220 V. / m.second Signal to noise ratio of 100 dB. Dimensions: 440x151x415 mm. Weight 11.5
The devices have gone full! professional inspection and prevention.
Detailed photos on request.
Sending in high-quality packaging.
Asking Price: $3500
« Last Edit: 16 Jun 2019, 10:57 am by bboyblaster »
bboyblaster
Re: Harman Kardon X-I X-II
« Reply #1 on: 16 Jun 2019, 10:58 am »
new price - $3500
