Accuphase M-60
0 Members and 1 Guest are viewing this topic. Read 1969 times.
bboyblaster
Accuphase M-60
« on: 31 May 2019, 07:45 pm »
Balanced monoblocks M-60 laboratories Kensonic, the company "Accuphase" are offered for sale. These devices can be used without a pre-amplifier, high-precision discrete volume controls, coupled with informative dial gauges, allow you to set the volume per channel without the slightest problem, and other adjustments in this High End are useless. However, if you wish, you can use a pre-amplifier "Accuphase" from any other series, preferably a balanced one. How preamps of other firms will behave can only be established empirically.
The output power of the monoblocks is impressive, but the adjustment of the signal level is very smooth, so even for a bunch of low-powered speakers you can not worry. The bass control of the amplifiers is phenomenal and will allow you to “keep in check” practically any acoustics.
The appearance of monoblocks - you can say the collection. The second owner, S / N 149 and 150. Inside - in general, as in the Paris Louvre - "the modest charm of the bourgeoisie." All components of the highest quality and class, not only at the time of release, but also by today's standards. But the increased attention to detail "Accuphase" has always been famous. Careful diagnostics showed that all the parameters correspond to the factory settings, so no interventions were required in the devices - everything was in its original state with the exception of the acoustic terminals. "Native" were designed only for bare wire of limited section, so it was decided to put modern ones. But not anyhow, but real German WBT 0708 - the class of devices obliged. And installed network terminals with filter power company Epcos.
Well, a few words about the sound. Accuphase amplifiers have their own musical handwriting which cannot be confused with anything. There are no genre preferences for devices! Dimensions; Width 482 x Height 170 x Length 345 mm Weight 27 kg.  Detailed technical specifications https://audio-heritage.jp/ACCUPHASE/amp/m-60.html Detailed photos on request.
The devices have gone full! professional inspection and prevention.  Sending in high-quality packaging.
Asking Price: $3500
« Last Edit: 16 Jun 2019, 10:57 am by bboyblaster »
paul79
Re: Accuphase M-60
« Reply #1 on: 31 May 2019, 11:18 pm »
So nice... Where are you located?
bboyblaster
Re: Accuphase M-60
« Reply #2 on: 1 Jun 2019, 07:15 am »
PM Sent
bboyblaster
Re: Accuphase M-60
« Reply #3 on: 16 Jun 2019, 10:58 am »
new price - $3500
