RM1 worth buying?
0 Members and 1 Guest are viewing this topic. Read 1357 times.
bcbud3
RM1 worth buying?
« on: 28 May 2019, 11:54 pm »
Found some locally.  Just wondering if they are worth buying or have they passed their best before date?  I have a pair of minitower 2's.  Are the RM! a step up or down?  Thanks
Stimpy
Re: RM1 worth buying?
« Reply #1 on: 29 May 2019, 11:38 pm »
If you're after bass response, probably go after the Mini Towers.  But, me personally, for better midrange performance, I'd opt for the RM-1's.  That 8" Neo panel is a great driver.  Well worth the investment.
fredgarvin
« Reply #2 on: 30 May 2019, 05:23 pm »
I'm with Stimpy, having had the RM1's and others, that mid panel is the magic of the RM series. One thing to check is the surround on the downfiring passive. I got good bass response from mine.
