0 Members and 1 Guest are viewing this topic. Read 2668 times.
A new CSS 12" passive radiator, should work, as an upgrade. They were being recommended as replacements, and then left the market for a time. But, CSS drivers appear to be back to normal availability.https://www.google.com/url?sa=t&source=web&rct=j&url=https://meniscusaudio.com/product/css-apr12/&ved=2ahUKEwjY3trxubfiAhXjmeAKHVV8B80QFjAAegQIARAB&usg=AOvVaw2ompB1IFu4idQie1NftQW9&cshid=1558813824197
A new CSS 12" passive radiator, should work, as an upgrade. They were being recommended as replacements, and then left the market for a time. But, CSS drivers appear to be back to normal availability.https://www.google.com/url?sa=t&source=web&rct=j&url=https://meniscusaudio.com/product/css-apr12/&ved=2ahUKEwjY3trxubfiAhXjmeAKHVV8B80QFjAAegQIARAB&usg=AOvVaw2ompB1IFu4idQie1NftQW9&cshid=1558813824197Oh, I've used Simply Speaker foam too, without issue. But, I like to also point people to Bill LeGall, at Millersound. Bill is the best speaker repair guy in the country.https://www.google.com/url?sa=t&source=web&rct=j&url=http://www.millersound.net/&ved=2ahUKEwikucecvbfiAhUvhOAKHcNxAeoQFjAcegQIBxAD&usg=AOvVaw0KCJBBTt8PnDCbgm4qlF7v&cshid=1558814696677
I wouldn't be concerned about the type of surround. There are different engineering reasons for a designers choice for various types of drivers. And FYI - PR's cab have immense excursion. I had old Dalhquists and Velodynes. I had them redone for me. While it can be done DIY - be prepared to be VERY patient, and it's critical you get the correct kit to do the job. NOTE - after you complete the job, it will take some hours to break in the suspension. During that time the bass will come back to normal. There are a number of companies that sell kits - it helps to know the brand of the driver. Check with John Casler for more info that he may have. You can use generic foams. In the meantime, you can GOOGLE speaker surround repair. Here's are a few links: https://www.midwestspeakerrepair.com/product-category/speaker-repair-kits/ https://www.simplyspeakers.com/speaker-foam-repair-new-edge-it-kits.html
If you can afford it, the CSS will exceed the performance of even the BiG Bump Passive Radiators.Not sure they will fit the cut-out, so you may have to surface mount, but since the PR is underneath that should not be a problem.Just make sure and tighten the screws in a manner that does not pull the PR off center so you have no air gaps.Properly mounted, they will give you a whole new speaker in the BASS.The screw pattern should likely match up.I would start with minimal washers like 3-5 and see how it sounds.You can even get some putty and place it on the screw off cup to "fine tune/putty pinch" if you feel it necessary. or fun.
