0 Members and 1 Guest are viewing this topic. Read 5091 times.
Hi all,I have been looking around for some rigid glass and have finally sourced some. I have the options of 2 or 4" OC 703 or some 3" from a different company. I am planning on using some of the 4" in all four corners but am not sure what the best options are for the ceiling corners and upper wall edges.What do you recommend? I have been reading some of Ethan Winer's recommendations so I am placing my corners and ceiling edge points as number 1.Thanks
Rather than 4" of 3lbs/pcf, I would go for 2" of 5-6lbs/pcf. Much more space efficient.Here's what I did for my 2" 3lb/pcf panels. If I were to do it again, I'd go with the 5-6lb./pcf.http://www.audiocircle.com/index.php?topic=11639&
Personally, I would go for the fiberglass pipe and stuff that with fiberglass rather than go for a large 4" thick panel, but I suppose it's left up to taste. For a dedicated bass trap, I think the tube is more space efficient. For something you can relocate around the room, I guess the panels would be more handy. Though a 4" panel is kinda thick IMO.
It may not seem like it, but 4" really does make an imposing presence. My $0.02.
