0 Members and 1 Guest are viewing this topic. Read 1848 times.
Redskinsfan,You will have to check with Meridian tech-support. The only incompatibility I foresee is if the amplifier output stage is either a bridge tied load (BTL), or balanced output in design. With this kind of output stage it would not be recommended (prohibited) to connect it to the high-level inputs of your sub woofer plate amplifier. The subwoofer plate amplifier high-level inputs are compatible with single ended amplifier output stages, in other words those that have positive (+) and ground only. Thankfully most solid state amplifier output stage designs are single ended. So double check to be sure. If I had a schematic I would be able to tell you.Best,Anand.
Thanks, Anand! I get the impression from what I've read that high-level speaker connection is preferable to line-level from a preamp, though I'm not sure why and whether it is true in all cases. I know it is the preferred method of the REL subs in that they have specially designed cables specifically for that.
I’ve played with both methods. Honestly I don’t find a difference as any system that I implement with subs always involves didactic and repeated in room measurements so that the subs and mains act as one and not a disparate set of sound sources. I will admit there is a convenience with piggybacking a set of speaker cables from your mains to your subs. You can use cheap and should use cheap speaker cables to your subs.That being said, regardless of the supposed sonic advantages purported by those “Hi Level” connecting enthusiasts and the REL marketing team what is most important is the integration of your mains, subs and room. At the end of the day I have never been able to address that without the assistance of measurements, room treatments, multiple subs and EQ. I do not have the golden ear so many audiophiles seem to possess! Good luck!Best,Anand.
