0 Members and 1 Guest are viewing this topic. Read 6944 times.
Hi All, I'm just not getting the sound-stage I expected from my current system. I've upgraded the Amp's tubes to Genalex Gold Lions, and the coupling caps to Mundorf EVO gold/silver/oil. Still no staging.I'm ready to spend $3k or so upgrading. I just don't know where to apply it. I'm wondering if the Bryston Pi streamer is my key problem (I hear the 'Pi' simply uses an Arduino to do the streaming). Next, maybe I shouldn't drive the amp directly from the Antelope... maybe I need a nice pre-amp (I was looking at a used Audio Research SP8). Anyway, below is my system's components. Any opinions on where I should upgrade (and maybe to what brand/model) is greatly appreciated. BTW, I do prefer used stuff.I have 4gB of music on a NAS feeding a Bryston Pi streamer, going to an Antelope Gold DAC that feeds directly into a Rogue 88 tube amp. My speakers are EPS Montana-2's. I use Roon.
So AudioEng, you and WitchDoctor seem to suspect its power or cable related. So I'll throw some money at those upgrades you're both suggesting (thanks). The jitter you mention from the streamer seems my suspicious point in the system. Maybe I should should dump the Pi and get a better streamer. I like Bryston's BDP-2, but I sense I may be paying for it's server capability and I already have a nice NAS. I've seen several Aurilic Aries streamers for sale.
I recently read a 2015 reveiw on the Antelope DAC that it didn't have a deep sound stage. So, I'd replace the DAC but I fear a new DAC will sound the same (as in, all DACs sound alike). Am I wrong?
If I did change DACs, would a tube DAC (like Audio Research's DAC-7) be an improvement? Or should I go with a much newer solid-state DAC like a PS Audio Stellar Gain? (I seldom play files higher than 192k). Thanks again for you and WitchDoctor's input.
Did you ever get an excellent sound stage? Could be as simple as bad speaker placement.As an experiment move your chair close as to make an equilateral triangle with the speakers. I'll bet you have a soundstage now.Adjust your music room accordingly to keep the soundstage you can live with.
So AudioEng, you and WitchDoctor seem to suspect its power or cable related. So I'll throw some money at those upgrades you're both suggesting (thanks). The jitter you mention from the streamer seems my suspicious point in the system. Maybe I should should dump the Pi and get a better streamer. I like Bryston's BDP-2, but I sense I may be paying for it's server capability and I already have a nice NAS. I've seen several Aurilic Aries streamers for sale. I recently read a 2015 reveiw on the Antelope DAC that it didn't have a deep sound stage. So, I'd replace the DAC but I fear a new DAC will sound the same (as in, all DACs sound alike). Am I wrong? If I did change DACs, would a tube DAC (like Audio Research's DAC-7) be an improvement? Or should I go with a much newer solid-state DAC like a PS Audio Stellar Gain? (I seldom play files higher than 192k). Thanks again for you and WitchDoctor's input.
How big is your room? How close are the speakers to the front wall? How close to the side walls? Do you have a rack with audio equipment between your speakers? Do you have glass between your speakers (TV)? Do you have glass behind/beside the speakers (windows)? What room treatment do you have? Is the floor hardwood or carpeted?
This thread is IMO in the wrong circle. As Tyson said, always check speakers, room, and physical setup first. Of course check for proper phase hookups. Most "over gear" for the given room and certainly the PBN Montana-2's could be a prime candidate for that! Imaging is mostly a factor of speaker/setup. I've found that center stage imaging is hugely affected by even a very small rack along the front wall between speakers. Stereophile's review of the original Montana's indicate much setup fussiness relating to horizontal dispersion but with very good imaging, so do play with physical setup first. Again, from Stereophile lateral dispersion is well controlled but the speaker is not time coherent, perhaps the later version corrected this.
I'd selected the Montana EPS-2 speakers because of their beauty, and because a review or two mentioned their sonic forgiveness when placed somewhat close to the wall. I clearly blew-off the meaning of 'somewhat'. One suggestion (thanks Sumoker) was to purchase the Spacial Audio M3 Turbo S speakers. OK, can do, but when reading those speaker's reviews I picked-up that they were 'relatively' forgiving about near-wall placement. Now I need to get some clarity on that word, 'relatively', since I don't want my optimism to cause me to park these things too close to the wall again. Any opinions about how close to the wall the M3's can be is appreciated.
Yeah, I'm gonna have to give those Montana's up. They do sound beautiful... though, I now realize, they're critical on placement if I want the imaging. Thanks AudioEngr. Any thoughts on whether the Spacial Audio M3 Turbo S speakers is my solution?
