0 Members and 1 Guest are viewing this topic. Read 6991 times.
I'm sorry about your disappointment, but the second paragraph on the Gridfusor product page identifies them as being made of expanded polystyrene: https://www.gikacoustics.com/product/gik-acoustics-gridfusor/. Should they have made this more clear somehow for you? RPG's Skyline and Vicoustic's Multifuser DC2 are also made of polystyrene, using primitive root diffusion, and they cost quite a bit more.
My guess is they're hot wire cut rather than molded to the finished shape, but that's hair splitting. I've never known any type of foam, expanded or extruded, to be what I'd call easy to paint... just too porous. Sealing with something more goopy, perhaps Duratex or similar, then finish color might be better. I can imagine the packaging to protect something like the corner you show being as disproportionately expensive when compared to the product itself.
Well, I'm not 100% sure I would have equated "polystyrene" with styrofoam even if I had seen it, TBH, but I was going off the recommendation of a GIK rep...so while your point that I should have maybe spent more time researching what I was getting is perfectly valid, their advice has always been pretty reliable in the past. And again, I'm not meaning to throw them under the bus...I have full intentions to remain a customer, and as soon as those well diffusors are back in stock, they'll be getting more of my money. Just posting this in case it's helpful to anyone else considering this option.
I find it helpful to use Google when I run across words that I don't know. Styrofoam is a trademarked term, similar to Kleenex.RPG also used to recommend water-based paint for their Skyline product. A Google search suggests that acrylic paint or else paint specifically marketed for painting Styrofoam should be okay, but it looks like oil-based or other solvent-based paints may damage the polystyrene.Good luck. I have Vicoustic Multifuser DC2s in gray (I ordered two panels individually first to make sure the appearance was acceptable).Young-Ho
AJ,I use GIK Gridfusors as well on my ceiling - several of them actually. We used a primer coat first on them so only one coat of water based black paint was needed. Next after arranging them on the ceiling, we built a wooden frame and wrapped the entire thing with acoustically transparent Guilford of Maine fabric. The wood frame pops off by removing screws on the edges if any maintenance is required or if I wanted to go for a different diffuser design on the ceiling. The frame and ceiling have colors that match such that the frame looks like a highlight.It was a DIY project for sure. I think I have 10 Gridfusors on the ceiling but you can’t see them! I may have 2 left in storage if you want them and I believe they are already pre painted in black.They serve their purpose very well in all honesty and are quite durable too once primed/painted.Hope this helps!Best,Anand.
My guess is they're hot wire cut rather than molded to the finished shape, but that's hair splitting.I can imagine the packaging to protect something like the corner you show being as disproportionately expensive when compared to the product itself.
I must agree with the OP. I purchased them knowing full well they are Styrofoam. But I certainly expected higher quality. I don't know, greater density or less of a packaging Styrofoam look, something like that. I wouldn't order them again but I am pleased with their absorption panels and bass traps. I'm also waiting on a 24×36 art panel absorber.
When I built (diy) my diffuser I put a skim coat of acrylic stucco base.Its formulated to adhere to styrofoam.Not only did it make a nice base, it toughened the whole thing upand made it a breeze to paint.It hangs on the wall behind my front speaks.<--- can see it on my avatar.You should be able to repair the damage with some canned spray foam, a knife and some sand paper.
When I ordered from a competitor, they had been cut with hot wire, and were shipped with the negatives as well as the positive, providing a block for shipping.
Hey Guys,I wanted to jump in on this. First thank you ajzepp for your feedback and I will look at the page to see if we can make that clearer. I don't ever want a customer to receive something they did not totally understand. With that said that material really is about the only thing we have been able to come up with that keeps the cost down. If you want to upgrade from that then maybe look at the Gotham Skyline we have, but those are nearly 3 times the cost. Hate to say it but building diffusors is just expensive anyway you look at it. GlennOwner - GIK Acoustics
