Yaqin SD-CD3 Tube Buffer
0 Members and 1 Guest are viewing this topic. Read 583 times.
trianglezerius
« on: 10 May 2019, 06:41 pm »
I'm asking $140 shipped to CONUS.
YAQIN SD-CD3 (with upgraded tubes Tung Sol)
Stereo Tube Audio Upgrade Processor(Tube Buffer)
Specifications
·        Tubes:                 6N8P × 2 (Cathode followers)
·        Output Jacks:     Two channels with two gold plated RCA jacks
·        Input Jacks:        Two channels with two gold plated RCA jacks
·        Input Impedance: 100KΩ
·        Distortion of Harmonic Wave: ≤0.03%(1KHz input)
·        Signal to Noise Ratio: >75 dB
·        Frequency Response: 10Hz ~ 100KHz (-0.1dB)
·        Supply Voltage: AC115V 60Hz
·        Power Consumption:   15W
·        Dimension:         17cm(W) x 20cm(D) x12cm(H) (7” x 8” x 5”)
·        Weight:                2.5kg (5.5lb)
·        Shipping Dimension: 27cm x 23cm x 21cm
·        Shipping Weight: 3.2kg (7lb)
Features
·        The power transformers manufactured with silicon steel sheet and high-quality oxygen-free enamelled copper wire;
·       Utilizes the audiophile capacitors and high quality metal precision resistors dedicated for audio frequency;
·       Beautiful aluminum chassis and panel with logo window and steel heavy duty chassis.
This processor employs cathode followers to improve your audio system. It outputs the same voltage as it receives. The voltage gain approaches 1. It also adds tube audio quality to digital audio, reduces work load of a receiver (or an amplifier), and makes speakers sound warmer and more finer.
This processor can be connected in various configurations. It is to be installed between an audio source and a receiver (or an amplifer). The audio sources can be a solid state CD/DVD player, MP3 player, iPod, electric guitar, or computer audio output.
Dual power supply voltages are available on this unit, 115VAC for North America, 230VAC for Asia and Europe. The unit is preset at factory for using with 115VAC.
The 6N8P tubes can be replaced with 6SN7.
