FS Salk Rythmic 12 Subwoofers (PAIR)
0 Members and 1 Guest are viewing this topic. Read 1632 times.
Jenner
« on: 8 May 2019, 02:01 pm »
For sale on Audiogon:
https://www.audiogon.com/listings/lis9e6bb-salk-sound-rythmik-12-subwoofer-subwoofers
This pair of incredible sounding subs were just built by Salk in March 2019. In MINT condition and include all the original packing materials, cables, speaker grills (still unwrapped unused). Also including 8 stainless steel Herbies Spike Decoupling Gliders ($150 value) if my asking price is met.
http://www.salksound.com/model.php?model=Rythmik+12+Subwoofer
They sound awesome in my 17x16x8 room, but sadly my room is nearly a perfect cube which is not optimal for long bass wavelengths. In order to avoid nulls they have to be located on the side walls in the middle of the room. The wife is not happy about this and to be honest I love how they sound but don't love how they look either. I am selling these with the intent of replacing them with a single dual woofer Rythmik sub that I can locate in the corner based on my calibration testing of a single Rythmik 12.
Asking $2300 which is $700 off list price and you don't have to wait 2-3 months for Salk to build them. They will ship via freight on a pallet as they are ~75lbs each and close to 100lbs when boxed up. If you would like a quote please contact me with your full shipping address. If you have an alternative address that has a shipping dock it might save some shipping cost as well.
(I am in CT and can arrange to meet you or deliver if you are close by)
Model   Rythmik 12 Subwoofer
Design   12 inch sealed Servo controlled
Woofer   12 inch (black aluminum)
Amplification   Self-powered
Dimensions   17" W x 19" D x 20.5" H
Weight   75 pounds 1 inch walls, Salk custom internal bracing
Warranty 5 years warranty on driver and 2 years on electronics
Color White automotive paint*
*If you would prefer gloss black or matte black I can have them professionally wrapped in automotive vinyl by a local high end performance auto shop
« Last Edit: 21 May 2019, 12:42 pm by Jenner »
paul79
Re: FS Salk Rythmic 12 Subwoofers (PAIR)
« Reply #1 on: 8 May 2019, 10:25 pm »
Do these have high level inputs (hook to your speaker wires)?
Also, what is the lowest high frequency cutoff?
Frequency range?
I looked at the site, and nothing is mentioned. Thanks for your help.
Jenner
« Reply #2 on: 9 May 2019, 12:30 am »
Sorry about that. If you clicked the link to audiogon you would see the rear of the subs and the amplifier plate. It shows the LFE/line-in and speaker level inputs. So to answer your question, yes it does and I included the picture here so you don't need to click through.
The amp is the A370-PEQ3. As for the cut off you can also see this on the plate but here is a link to the Rythmik amp info as well as the setup guide for the amp explaining all the features:
http://www.rythmikaudio.com/amplifiers.html
http://www.rythmikaudio.com/download/PEQ3_sealed_quickguide.pdf
If you look at the knobs you can see the crossover can be adjusted 25hz to 120hz
Frequency Response   14 - 200 Hz (-2 dB @ 14 Hz) with LFE inputs
14 - 100 Hz (-2 dB @ 14 Hz) with LINE IN inputs
Crossover slope   Selectable 12 or 24 dB / octave
Crossover range (Low pass)   25 - 100 Hz
Rumble Filter (High pass )   20 Hz 18 dB / octave
Hope this helps!
Jenner
« Reply #3 on: 23 May 2019, 08:03 pm »
SOLD
« Last Edit: 11 Mar 2021, 04:16 pm by Jenner »
