DVR for OTA
0 Members and 1 Guest are viewing this topic. Read 1227 times.
Don_S
DVR for OTA
« on: 23 Apr 2019, 08:21 pm »
Can anyone recommend a good DVR for use with an antenna?  I have been using Magnavox with great success but Funai has discontinued them. I need to add another DVR to my system and cannot find any brand I recognize.  Suggestions would be appreciated.  There has to be someone out there not subscribing to cable or satellite and using their box.
Also comments on this would be appreciated.  Thanks.
https://www.channelmaster.com/Stream_OTA_DVR_Bundle_p/cm-7600bdl1tb.htm
gab
Re: DVR for OTA
« Reply #1 on: 23 Apr 2019, 09:31 pm »
Don - I use a Tivo with an OTA antenna input.  Get one of their top of line units with at least 4 tuners and buy a lifetime subscription if the budget allows. Make sure its loaded with as big a hard drive as it will hold.
gab
Bob in St. Louis
Re: DVR for OTA
« Reply #2 on: 27 Apr 2019, 12:28 pm »
gab
Yip, this is what we have, wifey loves it (it's installed in her woman-cave, not the man-cave, so I don't use it). But she's got the lifetime deal and a massive harddrive.
The coax from the antenna on the roof goes directly into the TiVo.
