Hello from PA
0 Members and 1 Guest are viewing this topic. Read 1386 times.
lewdogg
Hello from PA
« on: 23 Apr 2019, 03:13 pm »
New member from Harrisburg, PA. Looking forward to digging into threads about value floorstanding speakers around $2,000. Can anyone direct me to the best place to look? Thanks so much!!
Re: Hello from PA
« Reply #1 on: 23 Apr 2019, 04:18 pm »
Welcome Lewdoog :thumb: Do you mean say new or used?
Values of used tend to vary according to supply/demand.
After 3 approved post you will allowed to search and other features.
twitch54
Re: Hello from PA
« Reply #2 on: 23 Apr 2019, 04:50 pm »
welcome Lew, from another 'Pennsyltucky' resident !
Phil A
Re: Hello from PA
« Reply #3 on: 23 Apr 2019, 05:51 pm »
Welcome!
lewdogg
Re: Hello from PA
« Reply #4 on: 23 Apr 2019, 06:54 pm »
Thanks! Yeah searching will help.  :wink:
New or used, I'm not picky. Obviously used is better value.
syzygy
Re: Hello from PA
« Reply #5 on: 23 Apr 2019, 07:23 pm »
Greetings from Picksburgh!
Re: Hello from PA
« Reply #6 on: 23 Apr 2019, 08:49 pm »
Welcome!
I'm a proponent of monitors/subs versus floor standers.  Floor standers can over power a smaller room and are harder to move if the space is multi-purpose.  Monitors generate mid/high frequencies where best done (away from walls).  A subwoofer can be added and dialed in to add the desired amount of bass, plus they can be located where most effective and additional subs can be used to reduce in-room bass peaks and dips.  Monitors are cheaper than floor standers and easier to ship, making them easier to sell on.
I'm also a proponent of active speaker design (one channel of amplification per driver with low voltage crossover feeding the amps).  Cost is lower compared to separates and performance is greatly enhanced.  Just add a DAC/preamp to your computer with a pair of active monitors to have a complete digital system (like I have).
Re: Hello from PA
« Reply #7 on: 23 Apr 2019, 10:48 pm »
Greetings & Welcome to AC lewdogg    :thumb:
lewdogg
Re: Hello from PA
« Reply #8 on: 24 Apr 2019, 01:14 am »
Welcome!
Thanks, JLM!
