Starting Point Systems DAC 3
0 Members and 1 Guest are viewing this topic. Read 2981 times.
« on: 23 Apr 2019, 03:27 am »
Not sure where to post this.
I have a Starting Point Systems DAC 3. Anybody know how to change the battery or upgrade it in any way?
RicoS
Re: Starting Point Systems DAC 3
« Reply #1 on: 16 May 2019, 01:04 pm »
A friend of mine asked me the same question but my post was removed for some reason.
Help is appreciated.
Thanks in advnace
Rico
8T_BoCO
« Reply #2 on: 16 May 2019, 02:18 pm »
You could try contacting the seller, user leopardo42:
https://www.ebay.com/itm/201486642344
This page shows a picture of the battery:
https://audio.starting-point-systems.com/
mresseguie
« Reply #3 on: 16 May 2019, 03:38 pm »
Hello, Mix4fix.
I did a quick search and found this:
"Includes :
1x Battery DAC board (mounted & tested)
2x NiMH Batteries (one is shown in the picture for scale, two are actually mounted inside)
Note : power supply is not included (any 12V-15V wall transformer will do, laptop supplies are ok too, car power also...)"
From this website: https://audio.starting-point-systems.com/
and on Ebay:  https://www.ebay.com/itm/201486642344
Toward the bottom of the page there is a photo of the two batteries. Looks to me as though it is very simple to replace them. $215 + shipping is a GREAT price IMO.
This DAC3 reminds me of my dB Audiolabs Tranquility NOS DAC which also uses the TDA1543 chip. Mine is not battery powered however. I suspect your DAC 3 sounds sounds great. Sorry I didn't find how to change out the batteries, but (without looking at the inside) I suspect it's fairly simple to accomplish.
Michael
