SOLD!!!! Audio by Van Alstine ABX component switch comparitor
0 Members and 1 Guest are viewing this topic. Read 837 times.
Kwebb
SOLD!!!  This AVA ABX Switch can be used to evaluate cables and component parts as well as electronics and loudspeakers.  It can also be used for those that have more than one audio system for ease of switching.  Controlled by a universal remote, the ABX switch has the capability of:
Precise volume level matching, within 0.1 db, of any system.
Blind test modes (either informal or formal) force evaluations by how it sounds.
Works with or without a subwoofer.
Programmable power-up state and adjustable display brightness.
Persistent volume settings power up the same as they were when last powered down.
Multiple systems can be set up permanently and switched in/out with remote control.
Low noise.
Built in "Y" splitter can be used to drive two units with one source. Allows selection of up to two speakers at the same time. Mute entire system with a single button. Gold plated RCA connectors for line level signal connections. DC coupled (no capacitors in the signal path). Ground lift capability should a ground loop noise problem exist.
I bought this AVA ABX component switcher earlier this year but never used it.  It is new inbox.  Paid $1,099 for it, for sale at $750.
« Last Edit: 21 Apr 2019, 05:30 pm by Kwebb »
