0 Members and 2 Guests are viewing this topic. Read 70172 times.
Hi all,I also do use tweaks A lot. As long as they are sensible.I installed a low jitter masterclock in my CD player, with it's own power supply.Gave the digital circuit it's own 80VA toroidal transformer, with shottky rectifiers, and nichcon KG buffers.Also i split up the power supply and divided, so each chip got it's own regulated low noise feed. Spdif, decoder, dram etc, i removed the system clock, and gave each chip that needed it it's own low jitter clock.The tweaks work. It changed my former mediocre Marantz CD72SE, to a really singing highend player.Although i now use a seperate dac now, modding the player to use it as a transport, was beneficial.The cleaner the spdif signal enters the dac, the better it sounds...
The clocking and the clock power supply has a huge impact on the results. Jitter is a significant problem and higher quality clocking makes all the difference. With a good clock you can hear the image get wider and deeper. You can hear the room sound on the drums. You can hear the details of the reverb and delay on the vocals better. You often hear things in recordings that you never knew were there.
I'm looking to tweak some Elac Debut 6.2. The kit was purchased through GR Research. Looking for some pictures of completed crossover.
The one "tweak" that I have tried that made a noticeable difference to me were the vibrapods and cones.
Stabilant 22. Originally designed for NASA. It improves the electrical connection at the molecular level. I use it on all interconnects.
It's a bit expensive...
