FS: Line Magnetic LM-502CA Tube / SS DAC SOLD
0 Members and 1 Guest are viewing this topic. Read 729 times.
kgturner
« on: 18 Apr 2019, 12:40 pm »
Selling my gold Line Magnetic LM-502CA DAC. You can easily switch between SS or Tube output. I preferred the tubed output personally. Inputs are USB, AES/EBU, BNC, Optical, & Coax so it's take *almost* anything you can throw at it.
I have all the original packaging material, but not the box. I have another sturdy cardboard box as well as the manual and will ship for FREE at my asking price within the continental USA. I'm pretty sure I have the driver CD somewhere, but if I cannot locate it, I saved the files on my computer and will include them on a thumb drive.
The 502CA comes fitted with an NOS Sylvania 6X4 rectifier tube & a pair of MOS Mazda / CIFTE 12AU7 tubes. I will also include a 6Z4 tube & a pair of new production Tung-Sol 12AU7W tubes.
Please add 2% for Paypal.
Features:
ESS 9016 DAC chip
XMOS asynchronously USB 192KHz
Sampling rate: 32bit 44.1KHz, 48KHz, 88.2KHz, 96KHz, 176.4KHz, 192KHz
Input: AES / EBU, BNC, USB, OPTICAL, COAXIAL
Tube and transistor outputs are optional
LCD screen display
Two high-quality power transformers
Digital circuit power supply using O-type transformers
Analog circuit power supply using EI-type transformer
Digital circuits using high-speed rectifier
Analog circuit tube 6Z4 rectifier circuit (jumper switchable to 6X4)
Transistor output circuit using advanced op amp
Tube output circuit using two 12AU7
Specification:
Sampling rate: 32bit 44.1KHz 48KHz 88.2KHz 96KHz 176.4KHz 192KHz
Total Harmonic Distortion: Tube 0.5% Transistor 0.02%
Machine frequency response: 15Hz - 50kHz
Signal to noise ratio: Tube 92dB transistor 98dB
Vacuum tube: 12AU7 * 2, 6Z4/6X4 * 1
Dynamic range: 120dB
Digital input impedance: 75 ohms
Output Impedance: Tube 2 kohms, Transistor 600 ohms
Output voltage: tube 3V + -0.5dB, transistor 2.5V + -0.5dB
Dimensions (W x D x H): 17.1" x 12.8" x 4.1"
Kevin T
« Last Edit: 9 May 2019, 11:21 pm by kgturner »
kgturner
bump
« Last Edit: 6 May 2019, 03:06 am by kgturner »
kgturner
bump
