What about CD Changer's,anyone using one?
0 Members and 1 Guest are viewing this topic. Read 1822 times.
ABEX
« on: 12 Mar 2003, 10:39 pm »
I had thought about this before I had the mods done and did not think about it until the question came up on AA.
Has anyone used a 100+ changer with the modified Art DAC?
http://img.audioasylum.com/cgi/i.pl?u=users/7184&f=Sea_of_jukeboxes.JPG[/url]
witchdoctor
« Reply #1 on: 18 Mar 2003, 06:02 am »
Yes. I had a 200 disc Kenwood changer> DIP > Bolder modded Art Di/O.
There is nothing better than parking my butt on the sofa and letting the good times role. This DAC sounds great in this set up. Then I started looking at daisy chaining changers and had a better idea.
I bought a home theater computer , the RKR Cassini from digitalconnection.com.
Musicmatch Jukebox is way more flexible than a changer. I use an M Audiophile sound card as the digital out. I also use a plug in called DFX which actually sounds better than listening to the CD from my computers drive.
Either way should be fine.
