AXPONA 2019
0 Members and 1 Guest are viewing this topic. Read 3360 times.
  • The Demo is Everything!
    • http://www.bryston.com
AXPONA 2019
« on: 12 Apr 2019, 01:58 am »
BRYSTON AT 2019 AXPONA EXPO ROOM 440
Bryston will be exhibiting at the 2019 AXPONA expo and demonstrating a unique active system this year.
Bryston’s Gary Dayton will be using the extensive DSP engine in the SP4 preamp/processor to build a complex 3-way active speaker network. Loudspeakers will be the Bryston Mini T active driven by the brand new 21B3 amplifiers. Source will be the BDP-3 digital player featuring Qobuz playback.
Please join Gary Dayton in Room 440 for a Bryston demo and/or to discuss any Bryston products.
Re: AXPONA 2019
« Reply #1 on: 16 Apr 2019, 05:33 pm »
witchdoctor
Re: AXPONA 2019
« Reply #2 on: 17 Apr 2019, 03:59 pm »
I like it, using the SP4 as a 2 channel pre is a statement. Were you happy with the show?
Re: AXPONA 2019
« Reply #3 on: 17 Apr 2019, 04:02 pm »
Yes it went well and the SP-4 has the ability to drive the speakers 'Active' as the DSP allows for active speaker curves.
james
witchdoctor
Re: AXPONA 2019
« Reply #4 on: 17 Apr 2019, 04:07 pm »
james
Did you use the DAC in the SP4 or something else? Source?
Re: AXPONA 2019
« Reply #5 on: 17 Apr 2019, 04:38 pm »
They used the BDP-3 as the source and the DAC's in the SP-4.
james
witchdoctor
Re: AXPONA 2019
« Reply #6 on: 17 Apr 2019, 05:24 pm »
Interesting, that really says a lot about the capability of the SP4. First that you can use it as both a reference two channel pre as well as a multi channel pre. Second, that the DAC's are reference quality. I know how revealing active speakers are and any short comings would have been under the magnifying glass. Congrats!
Grit
  • - Garrett
Re: AXPONA 2019
« Reply #7 on: 18 Apr 2019, 06:04 am »
james
My hangup about getting an SP4 is no analog bypass. But, if the SP4 is on par with the BDA-3, then it wouldn't be such a concern initially. Can you give us some idea of how the SP4 compares to the BDA-3 through the SP3 on analog bypass? I just presumed the BDA-3 w/an analog bypass would sound better.
Re: AXPONA 2019
« Reply #8 on: 18 Apr 2019, 12:57 pm »
Hi Grit
The BDA-3 would still be the better choice for ultimate fidelity and flexibility.  The SP-4 operates at 48K/16BIT whereas the BDA-3 is capable of 192K/36BIT and DSD playback.
james
Grant Hill
Re: AXPONA 2019
« Reply #9 on: 18 Apr 2019, 03:14 pm »
Hi Grit
james
actually up to 384kHz/32 bit Sir  :wink:
Re: AXPONA 2019
« Reply #10 on: 18 Apr 2019, 03:30 pm »
Your correct - my error - I can't seem to find any material though.
james
Joe Frances
Re: AXPONA 2019
« Reply #11 on: 18 Apr 2019, 09:11 pm »
james
Did you get stuck in the snowstorm?
Re: AXPONA 2019
« Reply #12 on: 18 Apr 2019, 09:41 pm »
Hi
No made it out the next morning as planned - you?
James
MarvinTheMartian
Re: AXPONA 2019
« Reply #13 on: 23 Apr 2019, 12:35 pm »
Gary:
Interested in the procedure you used to develop the active crossover in the SP4.
Entirely Dirac based x-over implementation and optimization OR  Import the existing BAX-1 filters directly into the SP4?
James:
Also curious in your opinions on Dirac room correction, now that you have had a lot more play time.
Shawn
Re: AXPONA 2019
« Reply #14 on: 23 Apr 2019, 03:35 pm »
Gary:
James:
Shawn
Hi Shawn
I am OK with DIRAC below 100Hz  but not a fan above that frequency unless absolutely required.
james
« Last Edit: 28 Apr 2019, 11:57 am by James Tanner »
Mike-48
Re: AXPONA 2019
« Reply #15 on: 28 Apr 2019, 04:58 am »
Hi Shawn
I am OK with DIRAC below 10Hz  but not a fan above that frequency unless absolutely required.
james
James,  Based on your past comments, I assume that's not a typo, but I thought I'd check anyway, in case things have changed.  --Mike
Re: AXPONA 2019
« Reply #16 on: 28 Apr 2019, 11:57 am »
HA - thanks for catching that - I meant 100 Hz.
james
