Should single-driver speakers be called "active speakers" in common usage?
- Yes because it is the most technically correct/accurate terminology
1 (5.9%)
- No becacuse it is not the most technically correct/accurate terminology
12 (70.6%)
- No because although technically correct/accurate it is not the generally agreed upon terminology in the industry
1 (5.9%)
- It does not matter because either term won't change my understanding of the subject
2 (11.8%)
- It does not matter because neither term will confuse a non-technical casual observer enough to matter
1 (5.9%)
Total Members Voted: 17
0 Members and 1 Guest are viewing this topic. Read 6004 times.
