sound card w/ coax digital out?
0 Members and 1 Guest are viewing this topic. Read 3118 times.
lcrim
« on: 28 Jan 2005, 05:57 pm »
Can anyone please suggest a bit-perfect sound card that includes a coax (SPDIF) digital output.  There seem to a lot of inexpensive DAC's that only have coax inputs.  Not too many include Toslink.
TIA
John Ashman
    • http://forum.adnm.com
« Reply #1 on: 28 Jan 2005, 06:06 pm »
M-Sound.  I have one for my computer - it was the only one I could find wth coax (easily).
lcrim
« Reply #2 on: 28 Jan 2005, 06:30 pm »
John Ashman:
Could you furnish a link?  Google reveals nada.
Brad
« Reply #3 on: 28 Jan 2005, 06:31 pm »
I think it's M-Audio
lcrim
« Reply #4 on: 28 Jan 2005, 06:53 pm »
I found the M-Audio revolution 7.1 which does indeed include a coax digital output.   I expect some complications getting it to work w/ Foobar 2K but, its a start.
ted_b
« Reply #5 on: 28 Jan 2005, 07:05 pm »
Also, realize that for $25-40 you can get a toslink-to-coax converter; so you don't need to limit your shopping.  That being said the M-Audio's are nice, and most are bit-perfect (assuming you download the right drivers).  The Chaintech AV710 (my card) is the least expensive bit-perfect card I know of ($25), but has toslink outputs, so the converter price needs to be added to your math.
A good discussion on this stuff is on headfi.org's "computer-as-source" forum.
Ted
lcrim
« Reply #6 on: 28 Jan 2005, 10:27 pm »
ted_b:
I have an active post re: this same issue over on the computer-as-source forum @ head-fi.org.
Re: the toslink to coax converter-there is no reason to fear degradation or induced jitter from such a device?
If you don't mind-Why the Chaintech AV 710 and are you running a fiber cable to an external DAC or using the onboard Wolfson chipset for D to A conversion?  If so, how is the sound and what cable adapters are needed?
ted_b
« Reply #7 on: 28 Jan 2005, 11:06 pm »
Currently my Chaintech is my pc audio card; meaning, I use the internal Wolfson DACS and run it to my headphone amp to power my Sennheiser 580's as my home office/pc system.  I use flac files and foobar2k running kernel streaming; the card is set to hirez output  (which means you use the black output, which is normally set for rear surrounds).  I have used it with a Rat Shack toslink converter and sent a dig coax (Stereovox HDXV)  to a Scott Nixon Tubedac+ which was in my main system.  It sounded great.   I'm sure it's not the Lynx, but it's a great bit-perfect vehicle.
Ted
John Ashman
« Reply #8 on: 29 Jan 2005, 12:34 am »
Quote from: Brad
Doh!
EchiDna
« Reply #9 on: 29 Jan 2005, 03:26 am »
Quote from: lcrim
No issues getting it to work with foobar2k here.... I was using the exact setup described sionce the Revo came out...
CSMR
« Reply #10 on: 29 Jan 2005, 05:03 am »
The M-Audio Audiophile and Ego Systems Waveterminal U24 are also ones to consider. I think these have good quality digital out. Optical->coaxial by a Monarchy dip or something like that might also be an idea.
mcgsxr
« Reply #11 on: 29 Jan 2005, 11:46 pm »
I am following this with much interest, as I will eventually augment my cd front end with a PC solution of some kind - thanks for asking this lcrim!
Oh, and since I already have an older Monarchy DIP, that Chaintech will likely do the trick for me...
jermmd
« Reply #12 on: 30 Jan 2005, 12:01 am »
Do any of the motherboards with digital audio out give you a bit perfect data stream? Via coax?
Joe M.
