airplay 2, wifi and bluetooth
0 Members and 1 Guest are viewing this topic. Read 1547 times.
harley52
« on: 25 Mar 2019, 12:42 am »
 Not sure if my understanding is right on this wifi thing. I understand wifi goes thru your router and from the router to a speaker or some device.  :lol: I guess the speaker has to be wifi capable? :scratch:
 Bluetooth is line of sight. It's major short coming.
 Airplay/airplay 2.  Airplay 2 goes to Apple TV and Apple TV is capable of sending out a signal to multiple speakers in multiple places?
 Can different speakers have different capabilities or do they all have to be the same OS? Say, I have to choose which system I'll use and then be locked in to that system or is DTS-Playfi a system where you can have for example, one speaker bluetooth capable and another airplay 2 capable. A mix of systems?
 One more thing. Why do I have all three systems on my iPhone and MacBook Air?
 Thanks to anyone and/or everyone that can help me understand all of this.
brj
Re: airplay 2, wifi and bluetooth
« Reply #1 on: 25 Mar 2019, 02:09 am »
IR is line-of-sight, but like WiFi, Bluetooth is RF based and can penetrate walls, etc..  (Up to a point.)  My Apple TV is located in the crawlspace below my listening room and the Bluetooth based remote has no problems controlling it.
Airplay and Airplay 2 are Apple protocols that ride on top of either WiFi or Bluetooth.  (Bluetooth is peer-to-peer.  WiFi can be, but most often relies on a router as part of a network.)
Doublej
« Reply #2 on: 25 Mar 2019, 11:53 am »
Yes, different devices can support multiple methods of transmission and protocols.
A good example is an AVR. Mid levels ones ($300+) can use wired network, wifi, or bluetooth for transmission.
They typically have Airplay, built in internet radio streaming, DLNA/UPnP for accessing music on your computer or network, and/or Chromecast built in.
Bluetooth was designed to be simple point to point such as phone to speaker. Networks are more sophisticated but more difficult to use.
