Decware EL34 SET amplifier
0 Members and 1 Guest are viewing this topic. Read 1625 times.
doctorcilantro
« on: 19 Mar 2019, 08:24 am »
Hey folks,
I've got two pieces left of my last stereo system. This beauty was the centerpiece of my SET system using the Zu Union Cubes (real bang for the buck!).
Here is the quick run down:
First owner
Single stereo input
No gain control
110 voltage
Switch for hi/low impedance (
Fully upgraded equivalent to current model: VCAPS, UFO transformers, bias mod
Black Limba exotic base
I have some nice tubes I will include: POPE 7DJ8/PCC88 (Upscale Audio), EL34 PSVANE smoked Treasure II, new production Tung Sol EL34(brand new), Gold pins Gold Grid 6N1P-VI (6DJ8 ECC88 6922) pair, another pair of Russian input tubes recommended by Steve (need to check which I have), stock 5U4 rectifier.
Asking $1775 net total shipped.
This amp uses a pair of 6N1Ps driving a pair of EL34 output tubes. You can alternately use 6N2P, 6DJ8, 7DJ8 or 6922 in place of the 6N1P.
EL34 output tubes may be substituted with the following: KT77, 6550 KT66 KT88 6L6s, 7027 and with a socket adapter, 807.
Because this amp has the Hazen Grid Mod that activates only when EL34s are used, we ship the amp with top grade EL34/6CA7s that have been fully tested IN the amplifier. All tubes come with a 90 day warranty.
doctorcilantro
Re: Decware EL34 SET amplifier
« Reply #1 on: 22 Mar 2019, 08:13 am »
bump
