BP17 cubed question....
0 Members and 1 Guest are viewing this topic. Read 2234 times.
redbook
  • the music is the blood...........
« on: 7 Mar 2019, 07:29 pm »
  Forgive my ignorance but I wish to know  if the bp17  has a polarity reverse feature. My bp25 has a toggle switch  and it looks like the 17  may do it with buttons ...can't tell for sure  . I have found this freature to be very useful...thanks :scratch:
gberger
  • Check 6
Re: BP17 cubed question....
« Reply #1 on: 7 Mar 2019, 08:38 pm »
No, the BP173 does not have polarity reverse.
My BP-26 does.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 7 Mar 2019, 09:54 pm »
I think with the BR2 remote you can reverse phase on the BP-17 - I will check.
james
redbook
« Reply #3 on: 8 Mar 2019, 02:57 am »
james
......thanks  James...
redbook
« Reply #4 on: 8 Mar 2019, 10:55 pm »
james
  Hi James , any word on the polarity question... I am concerned because  on some recordings it has made a difference. thanks again... :thumb:
« Reply #5 on: 9 Mar 2019, 12:48 am »
Hi James
Reversing phase is not possible on the BP17.
Is this something we should have on the BP18?
gberger
  • Check 6
« Reply #6 on: 9 Mar 2019, 05:24 am »
IMO, it's a toss up.  I have it on my BP-26, but seldom use it, except on a few poorly-recorded 16/44.1 CDs
So far, I haven't missed it on my BP17c preamp.
It might be my choice of CDs, since I only play classical and organ CDs. No digital, hard rock, heavy metal performances.
Others, specifically Redbook and Elizabeth can honestly disagree, as they both do use it.
BTW:  James, you've said the BP18 will be a combination of the 26 and the DAC-3. Since the 26 has Polarity reverse, inclusion shouldn't be an issue.
George
redbook
« Reply #7 on: 9 Mar 2019, 11:20 pm »
Is this something we should have on the BP18?.... Well now that's news, didn't know about a BP18...mmmmm yes there's still hope  for the polarity feature...will look forward to further developments. :thumb:
George
ord.avg.guy
« Reply #8 on: 11 Mar 2019, 12:44 am »
Hi James
As a happy and content owner of a BP25 that does notice a difference with the polarity/invert setting I think you should include it on the BP18.  When I'm browsing PreAmps that is the first thing I look for, if it doesn't have it I'm not interested.
redbook
« Reply #9 on: 11 Mar 2019, 05:06 pm »
As a happy and content owner of a BP25 that does notice a difference with the polarity/invert setting I think you should include it on the BP18.  When I'm browsing PreAmps that is the first thing I look for, if it doesn't have it I'm not interested....... :thumb: :thumb:   Thanks  avg.guy
