FS: Groneberg Quattro Reference Speaker Cables, Banana's, 8' pair
0 Members and 1 Guest are viewing this topic. Read 463 times.
aaron.luebke
Groneberg Quattro Reference Speaker Cables.
8' pair
$225
Termination is ViaBlue TS2 Banana's with the crimp sleeves installed and soldered.  The banana's are attached with set screws and easily changed if needed.
Please look closely - the ends do not have a lot of distance between the ends.  If your speaker terminals or amp terminals are normally close they will work fine.  If your terminals are spread far apart (some speakers are like this) you'll have to rework the ends.  The end with the extra shielding goes to the amp.
